Mounting A Light From Ac Outlet Box Trouble - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2010, 05:51 PM   #1
Rewards Points: 12
mounting a light from ac outlet box trouble
ok so i thought i was golden. i wanted to put a motion detector light on the side of the garage. while there was no light box, there was a standard double outlet high on the wall that we never used. it was in the perfect spot and i figured the wires are all the same. i planned to just take out the handy box and mount a light box in the opposite direction to put in the light from outside. problem is, when i opened the box i found that the next outlet low on the wall (one that is in use) was wired in series from this plug. i need that other outlet so i can't just disconnect it. i was wondering how to proceed. i'm at the limit of my electrical knowledge. i wasn't going to just wirenut them together because the circuit is wired through the outlet with the corresponding wires on either side of the outlet.
so any help you can give me on how to get my light and still keep the second outlet would be very much appreciated
migelito is offline   Reply With Quote
Old 08-09-2010, 06:50 PM   #2
The new box is on the right. G=ground, W and n=neutral, H=hot, circles are wire nuts.
To keep the upper receptacle, use the first pic and replace the handy box with a 2-gang box to fit the recept. and the switch. To remove the upper receptacle, use the second pic.
If the boxes are metal (since you said "Handy Box") they need to be grounded.
williswires is offline   Reply With Quote
installation , light , outlet , series , wiring
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
adding outlet from light switch tad Electrical 17 06-05-2009 11:25 PM
re wiring switch outlet to a light outlet box heddie Electrical 9 11-09-2008 09:15 AM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
