Mounting Junction Boxes In Attic, Are Both Of These Locations Acceptable? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 07:19 PM   #31
Yes rgsgww, any non-metallic cables installed in accessible dwelling attics & installed away from the studs edge shall be physically protected & secured to running boards if within the measurements I mentioned earlier.
DragonInspector is offline   Reply With Quote
Old 04-08-2009, 08:13 PM   #32
Oh my gosh I like mole hills !!
Simply put
Old 04-09-2009, 06:17 AM   #33
zpm
yeah, right
Originally Posted by DragonInspector View Post
if is NOT a good idea to bury these junction boxes in the attic insulation since 1 it makes finding them later harder, but also, the conductors may NOT get the proper ventilation/cooling they may need if buried in insulation in a Hot SummerAttic envirement.
In an attic, stuff buried under insulation will be cooler than stuff in the open air. For example, last October 1st the outside temp at 4PM was about 95. The ambient air temp in my attic at the plate line above the insulation was about 95 or slightly higher. The air temp at the peak exhaust vent was 115. The temp under the insulation at the ceiling sheetrock was less than 80, about the same as the inside temp.
zpm is offline   Reply With Quote
Old 04-09-2009, 07:24 AM   #34
Its an oven in my attic. I would literally die in there if I went up there when its 100 outside. It lets up to 80 when its only 67 outside.
rgsgww is offline   Reply With Quote
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 08:40 PM
Mounting 3 gangable switch boxes mcvane Electrical 11 01-16-2009 08:43 PM
ceiling junction boxes DangerMouse Electrical 8 07-17-2008 06:44 PM
Electrical boxes in attic Cossack Electrical 6 02-27-2008 02:08 PM
