Mounting A Generator Inlet To The Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 04:23 PM   #1
Mounting a generator inlet to the breaker panel
I'm preparing to install a power inlet for my generator and have a couple questions about code. From what I've seen, my area just follows the 2008 NEC, and pretty much doesn't specify anything else.
I am using an (approved) mechanical interlock combined with a backfeed breaker. This mechanical interlock makes it physically impossible for both the main breaker and the backfeed breaker from being on at once.
My main panel is outside (a combination meter pan/breaker panel). I am planning on getting an outdoor rated L14-30 inlet (similar to http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053) and mount it in close proximity to the panel.
My question is, can I physically mount the inlet to the panel, or must I space it with a short piece of conduit? On the same note, can I secure the inlet to the panel (which is physically attached to the house) or must it be secured to the house itself? Thanks!
erickotz is offline   Reply With Quote
Old 06-19-2011, 04:30 PM   #2
Missouri Bound's Avatar
You will need to mount it to the wall and short nipple it to the panel. A close nipple would surely work. The box itself needs to be supported by means other than the conduit (nipple).
Old 06-21-2011, 01:54 AM   #3
Thank you
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
Generator wiring to Breaker panel Macklin Electrical 1 03-26-2011 08:18 PM
Breaker panel, lack of planning Jstdv8 Electrical 2 01-14-2011 05:54 AM
Sub Panel install eagertolearn Electrical 17 01-23-2010 06:39 PM
Slot #3 blocked in Q0N Breaker Panel dallen Electrical 5 11-05-2007 07:37 PM
