Mounting Fixture To Light Box Without Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2013, 05:12 PM   #1
mounting fixture to light box without ceiling
This has to have been addressed before but I couldn't search it out. I've got open joists with conduit running to octagonal light boxes. I've been using basic ceramic fixtures which fit nice and tight to the boxes but I want to put some decorative lighting in places and these all have mounting bases that are designed to press flush to a ceiling. Do I need to cut custom pieces of wood just larger than the light fixtures mount and use that in between the fixture and the electrical box or is there a commercial product that will do the job? I've even looked into round metal such as unused quart paint can lids with a hole cut in the middle for wiring to pass that could be used in between the box and the fixture. I hope this is clear enough. Thanks.
Gary Phillips is offline   Reply With Quote
Old 07-16-2013, 05:28 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Most ceiling mount fixtures have a base that are larger than the box, then the globe attaches to the fixture.
I don't see a need for anything other than the fixture.
Old 07-16-2013, 05:37 PM   #3
Originally Posted by jbfan View Post
Most fixtures have a base that are larger than the box, then the globe attaches to the fixture.
But the box often ends up fitting inside the fixture somewhat and is often difficult to get tight or doesn't fit flush. Also this leaves a large gap that is open to dust and bugs.
Old 07-16-2013, 06:57 PM   #4
MarginallyQualified
Rewards Points: 2,464
You need something to "mimic" the ceiling.
An round or square piece of sheetrock or plywood or paneling or sheetmetal or just about anything will accomplish this. All it has to be is slightly larger than the fixture base. Making it attractive is the only hard part.
Old 07-16-2013, 07:17 PM   #5
Resi EC
Rewards Points: 252
get a ceiling medallion, just a cheapy at one of the big box stores, turn in upside down and use the flat surface to support the fixture.
something like this
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 07-17-2013, 01:14 AM   #6
Originally Posted by Gac66610 View Post
get a ceiling medallion, just a cheapy at one of the big box stores...
Thanks. Not a bad idea. Can't find one at Lowes smaller than 10" in diameter though, and that's a bit large. But I'll keep looking. I've actually used small plastic plates in the past, but they are tough to drill through without cracking.
Ceiling Light Fixture Marama Electrical 5 05-19-2013 10:06 AM
Ceiling light fixture wiring eveready Electrical 2 03-10-2013 11:55 AM
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 02:01 PM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 12:52 PM
Problems Installing a Light Fixture onto a Ceiling Fan adk97 Electrical 4 08-16-2010 06:30 AM
