Mounting Electrical Boxes On Studs - Flush Or At Surface Depth? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 11:26 PM   #1
Mounting Electrical Boxes on studs - flush or at surface depth?
Hello All
So I have a beginners question. I am remodeling my basement. The existing electrical is fine, but all of the boxes were hung from the old wood paneling (not mounted to the studs) using some sort of hooks/pins. I had a friends dad (who is a master plumber) come in, and he said those pins are fine for occasional use, but should not have been used everywhere.
Should I mount the boxes to the studs? If so, should the boxes be flush with the studs, or should they be 5/8 extended out, so they will be flush with the Sheetrock?
My gut says 5/8 out, but watching youtube clips I only hear flush with the studs. Any feedback would be greatly appreciated.
Thanks.
-K
kuj0317 is offline   Reply With Quote
Old 04-17-2012, 11:37 PM   #2
Rewards Points: 13,450
There never flush with the stud, if 1/2" sheetrock is going on the walls then buy new constrution plastic boxes. There's rasied spots on the side of the box
for setting the boxes so they stick out 1/2 from the studs.
Do not break the tabs completly off where the wires enter the box, only break off one side. I strip 6" off the insulaion on the romex then slip the wires into the box until the inulation is about 1" inside the box. The tab keeps the wire from being able to be pulled back.
There needs to be a wire staple within 6" of every box in the stud.
Old 04-17-2012, 11:40 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Yes the boxes should definitely be mounted to the studs.
If you plan on putting 5/8 rock up then the box should be flush with the outside edge of the rock.
You may want to offset the box back just a little.
Much easier to deal with a box a little short of the rock then a box out beyond the rock!
sublime2 is offline   Reply With Quote
Old 04-18-2012, 05:44 AM   #4
DIY staff
Rewards Points: 7,174
That depends on the type of box you are using----if you are using a steel box --mount flush to the face of the studs and add the correct trim ring for the finish surface you choose--1/2"-5/8" or more--
Plastic boxes must extend past the face of the stud by the thickness of your wall finish--
Here we can only use steel boxes --so my knowledge of the plastic ones is limited---choose a box with enough volume to handle the number of wires----over stuffing a box is a nightmare to work on--and will violate local code.
Old 04-18-2012, 05:54 AM   #5
Civil Engineer
Rewards Points: 4,694
For about a dollar more per box, you can get adjustable plastic boxes with a screw you turn that moves the box in and out. You simply attach the box to the stud, then adjust it to position when the sheet rock is in. I like this approach, makes life easy, especially good when you are putting on a finish like tile where you may not know the exact depth in advance.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
kwilcox (04-18-2012), oh'mike (04-18-2012)
Old 04-18-2012, 06:52 AM   #6
Rewards Points: 1,494
The box rim (or any extension or ring) needs to come within 1/4 inch of the wall cover plate. You can get trim rings for plastic boxes also.
Old 04-18-2012, 08:28 AM   #7
Rewards Points: 3,130
Are you sure there are actually studs?? The paneling could be attached to the wall using furring strips.
Old 04-18-2012, 09:35 AM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Regardless of whether the box is plastic or metal, it has to be installed flush with the wall surface if it is combustible and no more than 1/4" setback in a noncombustible wall surface. Add-a-depth rings will also work.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following 2 Users Say Thank You to electures For This Useful Post:
kwilcox (04-18-2012), sublime2 (04-18-2012)
Old 04-18-2012, 02:42 PM   #9
Thank you everybody for your replies.
There are existing metallic boxes that are currently dangling after I removed the paneling. I will mount them to the studs, offset by 5/8s per your information.
Old 04-18-2012, 02:55 PM   #10
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Be sure to kill the power when you go to mount the boxes! Any loose or un capped wires that your not aware of in the boxes that come in contact with the boxes while you nailing to the studs can seriously hurt you!
Suggestions - Mounting TV (Metal Studs) HandymanCA Building & Construction 16 11-27-2011 01:36 PM
Rotozip: How to Use for Electrical Boxes ralphfravel Building & Construction 11 07-24-2010 08:35 AM
Blue electrical boxes are to far in the drywall smblank3 Drywall & Plaster 3 05-18-2009 11:37 PM
Electrical Boxes. topher0524 General DIY Discussions 17 03-08-2009 09:43 AM
Electrical boxes in attic Cossack Electrical 6 02-27-2008 02:08 PM
