Mounting A Ceiling Bathroom Fan In A Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 09:03 PM   #1
Mounting a ceiling bathroom fan in a wall?
Hello all.
I have a crappy old Broan bathroom fan that sounds like a jumbo jet taking off. It is wall mounted, not ceiling mounted. I have been looking for a replacement fan that would fit but it is very hard to find the same exact size.
The size of my fan is 8 x 8.25 x 5.75
This is the only decent and quiet fan that i've found fitting my mount size.
http://www.deltabreez.com/Products/VFB080C4A1.aspx
However I found out that that model cannot be wall mounted, only ceiling mount. That was confirmed by the customer support. This leaves me without any other options, as the Broan fan at home depot is loud at 6.0 sones. What i was wondering is could I still mount that Delta Breez fan in a wall? Would I be taking a risk by doing that?
Spetsnaz201 is offline   Reply With Quote
Old 05-30-2012, 09:46 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You could try getting the information from the fan motor and simply replace the motor. Otherwise you are pretty much stuck with abandoning the existing fan and putting a new one in the ceiling, or having some patch work to do after installing a new thru-wall fan.
edit: even if you could/would mount the fan in the wall, the fan you posted won't work the way you are thinking
1) The fan is too deep to fit in a 2x4 wall
2) you would have to patch the outside siding/brick
3) you would have to run a new duct from the fan's port which is on the side of the fan
Old 05-30-2012, 09:52 PM   #3
You may also be able to use a 12 vac or 24 vac "muffin" fan.
Old 05-30-2012, 10:46 PM   #4
Rewards Points: 826
I put one of these (Fantech) in my master bath with two grills. They are fabulously quiet, can barely tell they are on. Then just drywall over the old fan location.
http://www.waveplumbing.com/store/in...&cPath=476_325
http://www.youtube.com/watch?v=LWnep...ature=youtu.be
curiousB is offline   Reply With Quote
Old 05-31-2012, 04:26 PM   #5
Just a DIY guy
If you are looking for a through-the-wall fan, this one may work
http://shop.panasonic.com/shop/model/FV-08WQ1?t=specs
If you are looking for a wall mount fan that has a duct, you can try this one:
http://shop.panasonic.com/shop/model/FV-05VS1?t=specs
You will likely have to enlarge your opening, but that is pretty easy.
Panasonic fans are very quiet. Use Google shopping and you can find a good price.
M3 Pete is offline   Reply With Quote
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
How to fix a peeling bathroom ceiling lmaxson Painting 16 02-20-2012 01:55 PM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 09:20 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
