Mounting 200a Semi Flush Panel In Stucco - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 02:20 PM   #1
Mounting 200a semi flush panel in stucco
My new 200a semiflush panel came with an L shaped nailing flange that comes forward out to the face of the panel. (pretty ugly on nice new panel)
Q-Is this "extra" flange designed to be bent back over the nailing flange after mounting and before stucco? maybe to put the flasing in between?
maybe dumb question but i just want it to look right and to do it only once.
Picture of my panel attached
socalsteve72 is offline   Reply With Quote
Old 03-10-2012, 02:23 PM   #2
Rewards Points: 324
keeps stucko from binding door.
oleguy74 is offline   Reply With Quote
Old 03-10-2012, 02:36 PM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
The mounting flange allows you to put siding right up to the edge of the panel so all you will see is the panel just barely past your finished siding.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-10-2012, 02:38 PM   #4
this flange comes out 2" from the nailing flange, way past where the stucco will be (1+ inch stucco), i've never seen a panel installed with this sticking out. also the doors will be out past the stucco by at least 1/2 inch.
Old 03-10-2012, 02:43 PM   #5
i could see how that would be. so... what's the best course of action with my stuation?? what do you guys do in my case? bend it back, flash, and stucco?
Thanks in advance
Old 03-10-2012, 02:50 PM   #6
rrolleston's Avatar
Remove stucco and whatever else is there right down to the 2x4 or 2x6 whatever you have and nail the box right to the framing and once inspected go ahead and repair stucco. It's made to mount the panel and prevent your stucco from interfering with the proper operation of the doors.
The Following User Says Thank You to rrolleston For This Useful Post:
socalsteve72 (03-10-2012)
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 11:49 AM
2/2/2 AL into 200A panel njwoodworker Electrical 11 07-25-2011 02:00 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
Mounting Landscaping Lights to Stucco Jawbreaker General DIY Discussions 1 09-21-2010 06:51 AM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
