Mount A New Wall Switch Next To An Old One - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 11:56 PM   #1
Rewards Points: 310
mount a new wall switch next to an old one
I have a single overhead light with a single wall switch. I'm installing can lighting separately. Can I stick a single blue remodel winged single swich box next to the original construction existing single switch box and get it close enough to work with a double faceplate?
Or should I just move the new switch over an inch and just install it fresh with a new single faceplate?
I thought I could remove the existing box/switch - but since it's original contstruction, it might be hard to pull that box to replace with a new double.
denemante is offline   Reply With Quote
Old 09-28-2011, 12:46 AM   #2
Electrical Contractor
kbsparky's Avatar
Too far away.
What kind of box is the existing one? How is it fastened?
There ARE alternatives ....
Upload a close-up picture of the existing box so we can take a looksie ...
-KB
Old 09-28-2011, 12:52 AM   #3
Code05's Avatar
Rewards Points: 1,104
Originally Posted by jufengdhj View Post
If for me, I will chose your option 1.
2 boxes and 1 plate?
Code05 is offline   Reply With Quote
Old 09-28-2011, 05:34 AM   #4
Licensed electrician
Rewards Points: 1,876
Often if you cut the hole for the 2 gang box it will make it easier to remove the existing box.
Code05 (09-28-2011)
Old 09-28-2011, 07:32 AM   #5
Rewards Points: 150
An option might be to get a double 9combo) switche made to fit in a single box.
http://www.electrical-picture.com/wp-content/uploads/2011/4/14/how-to-wire-double-light-switchin.jpg
NancyNGA is offline   Reply With Quote
The Following User Says Thank You to NancyNGA For This Useful Post:
Code05 (09-28-2011)
Confusing wall switch, neutral wire ? TomK1 Electrical 5 10-04-2011 03:58 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
Help with four way switch jwetsit Electrical 3 05-04-2010 06:05 AM
What wall switch for bath fan/light/heater? janralix HVAC 8 07-20-2009 04:07 PM
