Mount Electrical Boxes In Exterior Stucco Wall. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 11:31 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
With a surface mount box and a (code required) in-use cover, the box sticks out almost 6". Recessing the box will make a much, MUCH cleaner look.
The Following User Says Thank You to k_buz For This Useful Post:
jimmy21 (07-10-2012)
Old 07-10-2012, 11:36 PM   #17
liscenced electrician
Rewards Points: 538
Originally Posted by CopperClad View Post
I understand that jimmy. Like I said, I'm no electrician.. I just think it would be easier to drill a 3/4 hole through the stucco, fish the wire, screw the weatherproof box to the stucco, sealant caulk around the box, hook your receptacle, put your weather proof cover and be done. As I'm not an electrician, help me to understand why the box in the wall is better as I will be doing something similar shortly..
He said he wanted to do some light fixtures, not receptacles. Not that really makes any difference. Surface mount boxes look like hell. The only time to use them is when you are running conduit surface mount, and you can't fish it in the wall. Because he didn't mention anything about running any conduit surface mount, there would be no reason to use a surface mount box. IMO the box i said i would use is the easiest option and would look the best. Same way i always do light fixtures. Stub out a wire before there is siding. After there is siding up, shove the wire back into the hole, drill a 3 5/8 hole. Use that bakelite box unless i hit a stud, then use a pancake box.
Oh i guess he did say he is doing a receptacle as well...... I would use the same box but in a single gang configuration instead of 3/0 for that. Just make sure to miss the stud
jimmy21 is offline   Reply With Quote
Old 07-10-2012, 11:40 PM   #18
k_buz's Avatar
Couple problems
1) no plywood behind stucco/foam board
2) OP said light fixtures and a receptacle
Old 07-10-2012, 11:44 PM   #19
Rewards Points: 538
Originally Posted by k_buz View Post
Couple problems
1) He said there is 1/4 hardi board over the studs. That should be just fine for the bracket to rest against.
2)I missed the receptacle the first time i read it, but it doesn't make a difference. They make those boxes in single gang configuration as well
Old 07-11-2012, 05:11 AM   #20
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Well of course it's easier, but easier comes at a price, in this case cosmetically, it would look absolutely butt ugly to do it surface.
Mount opposing outlet boxes dougp23 Electrical 2 11-07-2011 09:10 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 08:56 PM
Installing wall mount rack on a concrete wall? helpless handyman Building & Construction 5 08-20-2010 09:33 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-08-2009 11:49 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
