Old 12-04-2008, 05:37 PM   #16
Electrician's Helper
Pudge565's Avatar
Send a message via AIM to Pudge565
Motors
When I can find a scanner I will post a picture of how our shop teacher explained to us how to do it. It does makes sense now that he explained it to us. But I do know now that I need to work on ladder diagrams. I will be proficient at it by the end of the year.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Old 12-04-2008, 10:38 PM   #17
Idiot Emeritus
Motors
The drawing that Wirenut posted will work just fine. The motor starters (MS1, MS2, and MS3) can be 3 pole double throw relays as well.
The relays will be far less expensive, but the motors will need to be single phase, and be overload protected by fuses, separate overloads, or built-in thermals.
Rob
micromind is offline   Reply With Quote
Old 12-05-2008, 01:39 PM   #18
It was a dark and stormy
Yoyizit's Avatar
Motors
When you get a minute,
you should figure out AND gates and OR gates. And, Exclusive ORs. These "logic functions" are used everywhere.
E.g. the Check Engine Light implements an OR function. Any one or more sensors indicating car problems will light the light. Probably half a dozen sensors scattered throughout the engine and transmission feed this one light.
With paralleled N.O. switch contacts, or paralleled switching transistors, any one closing can run the motor.
N.O. switches in series implement an AND function; they all must be closed to pass current.
Old 12-06-2008, 12:48 PM   #19
J. V.'s Avatar
Motors
Originally Posted by wirenut1110 View Post
Here's one way it can be done
Wirenut, Thanks. That was what I would have drawn for the OP. Did you take a picture of the drawing? Oh. yes it looks fine and would be what the OP needed.
Carrier 58MVP Blower Problem mickd HVAC 37 01-26-2013 08:56 PM
Hitachi Miter saw trip 20A jamiedolan Electrical 43 11-25-2008 01:06 PM
110V-230V compatible electrical motors ??h? ogumodo Electrical 8 11-03-2008 10:11 AM
Inducer motors on Bryant 350AAV Rookietinner HVAC 1 02-18-2007 04:38 PM
Wisper aire whole house fans.Dual fan motors. Doug Crf Building & Construction 1 07-21-2006 12:48 AM
