Motorised Panel To Hide Some PC Montiors - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2007, 03:50 PM   #1
Motorised panel to hide some PC montiors
Hi. Can anyone please help me? I want to instal a motorised wooden panel in a desk unit that will drop to reveal my PC monitors (attached to the wall).
The panel will be solid (but not heavy, perhaps 6mm ply) so as to look part of the furniture/wall. I want it to rise and fall on the press of a button but cut itself off when it reaches either the bottom or the top. Any ideas how I could go about doing this simply and, importantly, not expensively? I'm a capable DIY'er - but wishing I had paid more attention in technology classes at school!
Thanks!
nathanmcg is offline   Reply With Quote
Old 11-25-2007, 04:48 PM   #2
Thumbs up
I would suggest a DC circuit using a motor from a tape player, CD player or something similar. The trick will be to stop it at the correct position (top and bottom). For this I would suggest a small reed switch (magnetic) imbeded into the door or frame. You could set it up lik a garage door with a track and pulley system. It will take some work, but should be cool when all complete.
Marlee is offline   Reply With Quote
Old 11-26-2007, 10:40 AM   #3
Rewards Points: 150
You could make up some concoction with a lever switch, pushbutton, relay etc, but I think an electronic solution would be more elegant. You might want to google specifically for 'motorized panel' - you should find the schematic.
One way to greatly simplify things is to have the panel go down by its own weight, maybe using a friction bearing to smooth the drop. And motor would only work for 'up'.
scorrpio is offline   Reply With Quote
Old 11-26-2007, 12:08 PM   #4
Don't reinvent the wheel. You can by motors and controls which will do exactly what you want, and all the problems are figured out. They're made for raising TVs out of cabinets at the foot of a bed, for one thing. They use a long threaded shaft, and a worm gear that drives it up and down.
Nate
NateHanson is offline   Reply With Quote
Old 11-26-2007, 01:40 PM   #5
Thanks.
Nate: I'm all in favour of not reinventing the wheel. Any ideas on product names for what you've talked about. I've googled several combinations of key word and can't seem to find anything.
Old 11-26-2007, 03:35 PM   #6
Try looking for "Linear Actuator" or "Linear Actuator Lift"
I think that should work. You might consider attaching the panel to a drawer slide, or drawer slides on each end, so that the slides are extended when the panel is up, and closed when the panel is down. That would keep the panel aligned, and moving smoothly, while the actuator would provide the motion.
Nate
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
