Motor Wiring Reverse Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 10:29 AM   #1
I need some assistance with the wiring of a Dayton 6K324BA 1.5HP motor to a dpdt switch for reversible operation. It has 7 wires coming from the motor (yel/blk, red, brown, orange, black, white, and yellow). i purchased a 3 position (on/off/on) toggle switch to handle this. http://www.grainger.com/Grainger/POW...e-Switch-2VLP1
any assistance is greatly appreciated.
Motor Wiring Reverse Switch-motor-wiring.jpg   Motor Wiring Reverse Switch-imag1094.jpg
whiskeyfingers is offline   Reply With Quote
Old 03-22-2012, 10:52 AM   #2
Rewards Points: 58
Look at the switch contact arrangement. You want to interchange the "red and the "black" leads to change rotation. Both leads are used in each direction. They are just swapped back and forth to accomplish forward and reverse. See the note on the nameplate? Do you have the contact layout for the switch. Draw it on paper and do the connections on paper before you connect the power.
Old 03-22-2012, 11:01 AM   #3
I don't completely follow. Can you describe what the connections would be and/or sketch a diagram?
Old 03-22-2012, 11:16 AM   #4
Rewards Points: 58
Find out where the black terminates and where the red terminates. Lets try an example as this is very hard to explain in this format.
This how it is wired right now.
Black terminates on terminal number 6
Red terminates on number 4
1) In forward black terminates on number 6 and red terminates on number 4
__________________________________________________ _____________
2) To reverse: black terminates on number 4 and red terminates on number 6
All we are doing is moving or interchanging each wire from it terminal using the switch.
I can try and draw it for you. Let me see what I can do.
Last edited by J. V.; 03-22-2012 at 12:04 PM. Reason: Add correct terminal numbers
Old 03-22-2012, 11:20 AM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Used to do this all the time with DC motors wish I could draw good diagrams. You could wire the starter to one side of the switch then run a jumper over to the other side of the switch but reverse the wires and connect the middle of the switch to the motor.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-22-2012, 11:57 AM   #6
Rewards Points: 1,294
I think what the OP is trying to do is wire the motor so that the switch, in the up position, will run the motor in one direction, and in the down position will run the motor in the other direction. Not good at diagrams so I can not help here. I could do it if it were in front of me
danpik is offline   Reply With Quote
Old 03-22-2012, 12:40 PM   #7
rrolleston's Avatar
Yes much easier to do than explain. Lots of things I can do but can't explain how to do it well.
Old 03-22-2012, 01:19 PM   #8
Rewards Points: 58
Here is a scan of the connections. The two switches shown are the ONE (1) you have. The single terminal on each switch are the commons on your switch. Center (middle) terminal post. Then connect as shown.
Sorry about the quality of the scan. I am a first time user.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
