Motor Starter And Control Switch.. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 01:52 PM   #1
Motor starter and control switch..
Hi gang,
New here but not new to the DIY world. I have a 7 1/2 HP 240/1/60 motor. The tag rates current draw at 32/29. My panel is ~80 feet from where the motor will go. Should I use a 50A service? Because the control room where the motor will ge controlled is another 20 feet from the motor, I suspect I'll want a 120V magnetic starter at the motor and a remote pushbutton switch at the control room. I have a Graingers close and have perused the starter selection but don't see an application for remote switch. All the switches are manual magnetic. Am I missing something??
Thanks,
Cam
CamSweet is offline   Reply With Quote
Old 02-22-2009, 02:04 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You can use a selector switch or a maintained push button if you want to use just one switch. You could also use 2 push button with a start/stop pushbuttons. A 50 amp circuit will be good.
wirenut1110 is offline   Reply With Quote
Old 02-22-2009, 02:08 PM   #3
Thanks.. I'm more confused about the contactor/starter. They all seem to be manually actuated..
Cam
Old 02-22-2009, 02:19 PM   #4
Rewards Points: 510
How much are you willing to spend? There are many options for you. I personally like IEC style combo starters. Smaller and have disconnect, overloads all in one.
Old 02-22-2009, 03:01 PM   #5
Oh. I knew I was going to spend $300 - $400, anyhow. Less is better... lol
Old 02-22-2009, 03:09 PM   #6
Rewards Points: 510
I would just get a manual starter. Like this http://www.grainger.com/Grainger/items/2MNH6
or like this http://www.grainger.com/Grainger/items/1H412
Of course sized for your motor.
FYI IEC starters have ol's built in, NEMA starters, heaters have to be purchased seperately unless you get a solid state.
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
3-way Ceiling Fan Dimmer? 47_47 Electrical 13 09-25-2007 09:31 AM
Hampton Bay Fan control switch vince Electrical 2 08-20-2006 05:00 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
