Motor Runs After Assistance - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 07:49 AM   #1
Motor runs after assistance
My ceiling fan motor only runs when I help turn it otherwise it will not run when power is on. Could the wiring have a short, the unit is about 9 years old.
aflac is offline   Reply With Quote
Old 02-28-2013, 08:16 AM   #2
joed's Avatar
Rewards Points: 13,346
Most likely it is a problem with the fan. Probably the capacitor inside. My experience has been that it is cheaper to buy a new fan than a new capacitor.
The Following 3 Users Say Thank You to joed For This Useful Post:
electures (02-28-2013), joecaption (02-28-2013), NJMarine (02-28-2013)
Old 02-28-2013, 04:17 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,508
Replace the start capacitor !
it will be under the motor hood.
Make real sure you use the correct replacement !
Do not use substitutes !
dmxtothemax is offline   Reply With Quote
Old 02-28-2013, 04:24 PM   #4
Licensed electrician
Rewards Points: 1,780
Motors should be started on high speed and then reduced. What speed are you starting yours on?
Old 03-01-2013, 06:02 AM   #5
Rewards Points: 347
If it's a capacitor start motor [half round cover on the outside of the motor], that is probably the issue. Caps can be had for around four bucks from the supply house or HVAC supply. Get close to the same specification cap.
If anything other than that, new fan is probably cheaper.
al_smelter is offline   Reply With Quote
Replacing furnace control board, need assistance, pics inside AdRock HVAC 18 01-26-2016 05:04 AM
First bathroom remodel, need some assistance... 7lazy77 Remodeling 2 02-10-2013 05:07 PM
Need assistance determining header specifications rgb71 Building & Construction 1 01-06-2011 05:38 PM
Need assistance installing brazilian cherry stairway BobS0327 Carpentry 8 09-07-2010 10:30 AM
Getting Contractor Assistance, Doing Work Myself Sean Building & Construction 4 12-27-2006 06:13 AM
