Motor Rating On Outlets? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2013, 12:47 PM   #1
Rewards Points: 992
Motor rating on outlets?
I just noticed that Leviton 6-20 outlets are rated to 2hp and 5-20 to 1hp.
Like most other people, I have been using them to 3hp and 1.5hp for years.
Is this actually an issue?
http://www.leviton.com/OA_HTML/Produ...minisite=10251
Toller is offline   Reply With Quote
Old 07-28-2013, 03:50 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Of course it's an issue, they will prematurely fail. Why do you think they are only rated for a specific HP?
Old 07-28-2013, 04:57 PM   #3
Rewards Points: 992
Checking my manuals; Jet, Grizzly, Sawstop, and Rikon recommend 6-20/5-20 for their 3hp/1.5hp tools.
Are Leviton inferior to other brands? What brand has a better hp rating?
What should be used?
Old 07-28-2013, 06:34 PM   #4
Electrical Contractor
kbsparky's Avatar
You apply those HP ratings when you are using those receptacles as the required disconnecting means.
Otherwise, you should not have any problems as long as you are within the amp rating of the receptacle/circuit.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
mpoulton (07-31-2013)
Old 07-28-2013, 06:45 PM   #5
Rewards Points: 992
That makes sense. Thanks.
Old 07-30-2013, 09:50 AM   #6
Rewards Points: 992
I contacted Leviton. They say that using it as a disconnect is irrelevant; the outlet must be rated for the motor using it.
For a 3hp motor they recommend a:
Did I get a moron, or is it true? Could Grizzly, Jet, Sawstop, and Rikon be recommending unsafe outlets?
Or is Leviton's 6-20 inferior to others? (nope, other brands are 2hp also)
Old 07-30-2013, 04:17 PM   #7
Oso954's Avatar
Rewards Points: 1,676
Could Grizzly, Jet, Sawstop, and Rikon be fluffing their HP ratings for advertizing purposes ????
I think kbsparky gave you the correct info.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
kbsparky (07-30-2013)
Old 07-30-2013, 08:49 PM   #8
Rewards Points: 992
Maybe. If they are only 2hp, then they are fine.
Perhaps the equipment manufacturers measure HP differently than the outlet manufacturers do.
My 3hp Grizzly cyclone is 22a, and my 2hp Sawstop is 13a. I suspect one is measured oddly.
Leviton specifically said that is not correct.
Old 07-30-2013, 11:58 PM   #9
Oso954's Avatar
Leviton did not say anything. It can't talk.
What you had was one Leviton employee talking and he/she was winging it.
Did you ask what code section requires it ? Or, what that employee's expertise was with the NEC ?
Your on/off switch is your disconnect, not your plug and receptacle.
Old 07-31-2013, 01:15 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,990
I agree that Leviton's employee was incorrect. Disconnecting devices are HP rated, not wiring devices. Wiring devices are current/voltage rated, because that's the only relevant rating. The HP disconnect rating is lower than the volt/amp rating for a device because the starting surge and inductive load of a motor tends to burn the contacts on disconnecting devices.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
kbsparky (08-02-2013)
Old 08-01-2013, 01:46 PM   #11
Rewards Points: 992
I spoke to CS at Hubbel and Cooper. Both say that the HP rating only applies when the outlet is used as a disconnect.
So I guess I am good with that.
Still, two people at Leviton told me exactly the opposite; exceeding the rating can cause a fire, even if it is never used as a disconnect.
Guess I should avoid using Leviton.
The Following User Says Thank You to Toller For This Useful Post:
Old 08-02-2013, 03:33 AM   #12
kbsparky's Avatar
The problem with those idiots at Leviton is you won't be exceeding the rating of the receptacle during normal use.
It's disconnecting or reconnecting under load that can cause overloading conditions when used on motor circuits.
Hence the reasoning behind my original assertion that those HP ratings apply only to when used as disconnecting means.
-KB
mpoulton (08-02-2013)
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 08:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
