Motor Direction - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2008, 05:18 PM   #1
motor direction
I recently replaced a hvac blower motor located in a convector. It is a 3 speed 110 v motor, direct drive with the squirrel cage attached.The motor can go clockwise or counter clockwise. It is spinning the wrong way. Turning the cage around does not help. Is there a way to change the rotation of the motor? Thanks.
rkahn1 is offline   Reply With Quote
Old 03-03-2008, 05:24 PM   #2
Union Electrician
goose134's Avatar
What's the make and model#? Perhaps we could get a wiring diagram from the factory.
goose134 is offline   Reply With Quote
Old 03-03-2008, 05:58 PM   #3
motor direction
The motor is a AO Smith 3 speed 1/30 hp, 120v, direct drive with a permanent split capacitor. Model is #9643. There are red, blue, yellow. blk. and white leads.
Old 03-03-2008, 07:07 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
from AO Smiths website, it cannot. It is listed as a ccwse motor. (that's counter clockwise shaft end). If it was reversible, they list is as rev.
Old 07-20-2008, 10:15 AM   #5
fan direction
There may be 4 short wires that are connected to each other near the top. These need to be disconnected and reconnected in a different configuration, that diagram is on your motor. At least that's what I had to do.
icantry is offline   Reply With Quote
Old 07-20-2008, 11:26 AM   #6
Rewards Points: 88
Try swapping the black and red wires. Another words move the black to where the red is, and the red to where the black is.
J. V. is online now   Reply With Quote
