Motion Sensor W/timer - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 08:02 PM   #1
Rewards Points: 264
motion sensor w/timer
I am looking for a device that will sense motion and, after a set time(maybe a couple of minutes), turn on a fan for a programmed amount of time. Maybe run for 5 minutes.
I am remodeling and will set the cat box under a counter top. There will be a duct to a fan, or a fan that is ducted, out the wall. When kitty gets in to do his business the timer will start and the fan will exhaust the stinky poo smell(that is tech jargon). I don't want to run the fan immediately because it may scare the cat. I have looked for Greenheck fans and controls but can't find what I want.
Any comments(other than getting rid of the cat : ) ) or ideas are appreciated.
7echo is offline   Reply With Quote
Old 12-19-2008, 08:22 PM   #2
Originally Posted by 7echo View Post
sense motion
which triggers a monostable multivibrator
which triggers another one
turn on a fan for. . .Maybe run for 5 minutes.
A 556 IC
http://www.kpsec.freeuk.com/555timer.htm
and a relay should do it.
If you can solder, these guys can help with the details
http://www.electro-tech-online.com/
and parts are available from
www.hosfelt.com
Old 12-19-2008, 08:32 PM   #3
Some of these sensors and timers may give you some ideas.
http://www.passandseymour.com/litera...sorsTimers.pdf
Plumbvoltage is offline   Reply With Quote
Motion Activated Light for Attached Garage jamiedolan Project Showcase 6 07-01-2010 12:52 PM
Combine Motion Sensor and Timer for One Light fritzycat1 Electrical 9 11-22-2008 01:25 PM
Problem with motion sensor switch & light usseabeemom Electrical 5 11-17-2008 05:54 PM
What type of wire to connect motion sensor to light? beezlebub03 Electrical 1 05-31-2008 01:16 PM
