Motion Sensor Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 01:05 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Motion sensor switch
I want to install a motion sensor switch on my attached porch to replace an existing single pole switch. This is the switch I have looked at but it is rated as "indoor".
http://www.homedepot.com/h_d1/N-5yc1...1#.UKkR7Wexw1E
I have not been able to find a switch that is rated for "outdoor".
My location is well protected from the weather by the porch roof. Do you think I can use this switch and will it hold up?
If anyone has a recommendation, please give me a link
Coastal South Carolina
Old 11-18-2012, 01:24 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
rj....I installed some of the Lutron occupancy sensors....love the little bastards (seeing how my wife and kids have not figured out what the off position on a light switch is)...
Here is a link to their 'selection'....
http://www.lutron.com/TechnicalDocum...%20Maestro.pdf
I had a quick look and did not find any reference to 'outside'.....
But from what you describe....I bet if you use an exterior rated plate or just take some RTV and run a seal around the edges....I would think you would be fine.
Your biggest issue will be water blown by the wind.....
Old 11-18-2012, 02:17 PM   #3
Oso954's Avatar
Rewards Points: 1,116
Most "exterior plates" are going to cover the motion sensor. I have not tried a clear plastic in use cover, but I would bet the sensor would not work under one.
I would take a look at
http://www.homedepot.com/buy/heath-z...l#.UKk_A4aQN8E
The sensor is outdoor rated. The switch isn't, but could be installed under a plastic in use cover.
Oso954 is offline   Reply With Quote
Old 11-18-2012, 02:20 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Many of those electronic switches (whether it be timers or occupancy sensors) do not work well in the cold.
Old 11-18-2012, 02:51 PM   #5
Rewards Points: 150
The OP is in the South Carolina Low Country... while they use the word "cold" down there, it's not the same word that you know, k_buz.
Dave632 is offline   Reply With Quote
The Following User Says Thank You to Dave632 For This Useful Post:
rjniles (11-18-2012)
Old 11-18-2012, 02:53 PM   #6
Might be easier to replacing the outside light with one that has a built in motion sensor.
toastandjam is offline   Reply With Quote
Old 11-18-2012, 03:03 PM   #7
k_buz's Avatar
Sometimes I give more information than what is necessary in the chance someone searches for the subject.
Old 11-18-2012, 05:16 PM   #8
A "Handy Husband"
rjniles's Avatar
How true! I was in Maine last week and it snowed (thought I would freeze to death). And I am a displaced Yankee.
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 02:00 PM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 08:52 AM
Dual-brite motion detector light to operate second light? downunder Electrical 2 09-10-2010 03:48 PM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 10:39 PM
