Motion Sensor Light Stays On - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 08:52 PM   #1
Motion sensor light stays on
Motion sensor light stays on at all times....no switch, light is fed from a continuous feed. Problem is at my aunts house over an hour away(so I'd prefer to get tips here before I go there) is it just the settings on the sensor? Change from manual to auto? Or has the photocell gone bad and is it time for a new fixture. And I live in bc, Canada. Thx
Bubski27 is offline   Reply With Quote
Old 06-05-2012, 08:57 PM   #2
MarginallyQualified
Rewards Points: 2,464
Buy a new separate sensor device to replace what is there.
Ideally it will mount to the fixture she has.
Old 06-05-2012, 09:44 PM   #3
Rewards Points: 24
There is an eye that picks up the light; sometimes, depending on where it is located, they get dirty, or, if there is a hood around the eye, I have found them packed with mud, in which wasps, insects, or whatever lay eggs, either of which will cause the sensor to think that it always dark. If you find that to be the case, you might try switching the breaker off so that it can cool down fully, clear the eye, and see what happens.
Old 06-06-2012, 07:30 AM   #4
Rewards Points: 1,294
Some motion sensors have a feature where if you turn the power off and on real fast it will over ride the sensor and keep the light on all the time. It could be there was a quick power blip which may have triggered this. Try turning the power to the sensor off for a min and turn it back on. This is usually the reset for this feature. If there is no switch for the light you will have to do it from the breaker/fuse box.
danpik is offline   Reply With Quote
Old 06-06-2012, 10:50 PM   #5
I thought that ALL motion sensing lights worked this way! Is this not so?
Old 06-07-2012, 07:57 AM   #6
I have some that do and some that don't. Besides whenever someone says "all" or "none" someone will always come up with an exception
The Following User Says Thank You to danpik For This Useful Post:
k_buz (06-07-2012)
motion sensor light stays on just for couple seconds. Shooloo2 Electrical 3 01-05-2012 08:01 AM
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 03:00 PM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 09:52 AM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 11:16 AM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 11:39 PM
