Originally Posted by Oso954
The motion sensor and control side of the relay should be on one source. The load side of the relay and fluorescent should be from a second source. (Both hot and neutral)
maybe thats just it one would think it shouldnt matter but perhaps i need a secondary source of power - rather than using one source in parallel, for the lights and sensor...
I was thinking that perhaps the sensor doesn't put out a proper sinusoidal wave that the SSR recognizes - and hence thats why it just hums and flickers.. i will give your suggestion a try though..
As for the other respondant:
Originally Posted by silversport
Is the existing wall switch location too far away from the second door to use an occupancy sensor switch?
yes its pretty far - ive toyed with the idea, but it's a bay door so a wall occupancy sensor would not work... but thank you for the suggestion
