Motion Sensor Flood Lights Staying On - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 03:03 PM   #1
I can fix that!
Rewards Points: 35
Motion sensor flood lights staying on
I have two seperate motion activated flood lights that sometimes choose to stay on full time. I think they are both the same model with two lights and the duel stage lighting (where they come on bright and then dim for the remainder of the time it is set for). They don't always stay on, but more often than not at least one of them is on all day/night. Do I need new sensors on these, or could something like water penetration cause the sensors to detect motion?
kuhlman is offline   Reply With Quote
Old 01-25-2012, 03:09 PM   #2
Julius793's Avatar
I'd go with replacing the sensors.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-25-2012, 04:11 PM   #3
MarginallyQualified
Rewards Points: 2,464
And if at all possible... put the sensor in it's own box somewhere else.
Motion sensor causing lights to flicker Zaunerstollen Electrical 30 11-27-2011 01:39 PM
Wiring receptacle > switch > motion sensor lights Van Home Electrical 11 08-09-2010 11:27 PM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
Multiple Motion Sensor Lights Tripping GFCI Wan Miguel Electrical 6 05-05-2010 11:01 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
