Old 12-02-2012, 11:29 AM   #1
motion light not turning off
would the photo cell have anything to do with tihs ?
phillycat is offline   Reply With Quote
Old 12-02-2012, 11:43 AM   #2
funfool's Avatar
Most likely is the problem.
I have seen some replacement photo cells available, if they would work for you not sure.
I usually end up just replacing the whole unit. They are cheap enough.
If I am charging the customer by the hour, for the time I spent working on old light, they could have just got a new one for same cost.
But you can try to replace the photo cell, maybe it is just dirty and needs cleaned.
Try moving the switch back and forth to testing, change the sensitivity of the switch and maybe fiddling with it is all it needs to make it work again.
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
confusion with track light stephenbishop Electrical 7 03-10-2012 02:37 PM
Motion Light and fluorescent lighting. Luckymc420 Electrical 16 03-09-2012 09:12 AM
Arc fault light briefly lit when turning circuit back on... darthsmozers Electrical 26 01-16-2012 11:04 AM
3 way motion light switch souciej Electrical 8 02-21-2011 02:55 AM
Another motion sensing light problem Steelhead Electrical 6 12-24-2008 10:50 AM
