Motion Light And Fluorescent Lighting. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 07:51 AM   #16
Originally Posted by frenchelectrican View Post
By the way I never read the bulb wattage if you are going to size the circuit or switch rating I have to go by ballast rating so you will have to look it up but IIRC 8 foot slimline they will take about 1.5 to 2.5 amp depending age of ballast itself.
Note: with bad slimline ballast they will draw more current than a good one will draw.
Merci,
Marc
Correct the circuit should be sized to the ballast rating. But, we don't know the ballast rating, and the sum of the lamp wattage gives me a good idea that his motion sensor is overloaded.
JRigby is offline   Reply With Quote
Old 03-09-2012, 08:12 AM   #17
New Info:
Well crap. I think I found something.
The Ballast is PN IS275P
http://www.robertsonww.com/products/...ets/IS275P.PDF
Its Electromagnetic and Instant Start. I didn't see the VA rating on the ballast or on the Spec sheet.
First picture is the light apart. Just one ballast per light I have 4 total.
Second picture is of the switch that is in it right now. Single throw single pull. The other switch is not related.
Third is the back of the motion switch.
Last is the Ballast.
I also notice that on the Spec sheet it says that my bulb (F96T12) is a 75 watt. When its clearly marked 60 watts. If my sensor is being over loaded can't I just wire in a relay? I don't know much on AC relays. Shouldn't be to hard to learn.
Last edited by Luckymc420; 03-09-2012 at 08:37 AM. Reason: Wrong order of pictures
Luckymc420 is offline   Reply With Quote
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
fluorescent light as junction box jimaro Electrical 1 11-13-2011 06:09 PM
Fluorescent light not lighting up / turning on ken.yong Electrical 13 09-24-2011 02:49 AM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 08:52 AM
direct wiring fluorescent light amakarevic Electrical 7 01-11-2010 09:03 PM
