Motion Light Always On - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2009, 09:54 PM   #1
Hello All,
I am completely perplexed by my new motion sensing security lighting. Several weeks ago I had an electrician install the light with a switch in the bedroom. The first light would never turn off, even after trying countless times to "reset it." I installed a new light today, figuring maybe the original had a bad sensor. It has been on nearly all night now. I put the sensitivity to the lowest level and time at 1 minute. It is pointed over my fenced in back yard (ie no deer or small animals setting it off) yet turns on for several minutes, turns off, and a couple minutes later turns back on.
If anyone has any ideas, power surges etc, please let me know. Other brands that work better (both have been heath zenneth) I'm open to suggestions.
Thanks, look forward to fixing this!
konabear is offline   Reply With Quote
Old 11-06-2009, 10:15 PM   #2
The light and switches is a state machine
http://en.wikipedia.org/wiki/Finite-state_machine
that goes from the "light always on" state to the "motion detecting state" depending on the position of the switch mounted on the light and the position and timing of the on/off switch.
Study the description in the owner's manual of how to get into all of the different states.
It's not just switch positions; it's also how long you stay in each position. What is confusing is that the light has "a primitive internal memory" and timers.
And anything moving within the "cone of detection" can trigger it.
Old 11-06-2009, 10:54 PM   #3
Licensed Pro
Sensitivity set too high or switch left in "test" position would be my first checks.
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Another motion sensing light problem Steelhead Electrical 6 12-24-2008 10:50 AM
Combine Motion Sensor and Timer for One Light fritzycat1 Electrical 9 11-22-2008 02:25 PM
Problem with motion sensor switch & light usseabeemom Electrical 5 11-17-2008 06:54 PM
What type of wire to connect motion sensor to light? beezlebub03 Electrical 1 05-31-2008 02:16 PM
