Motion Detector Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 09:50 PM   #1
motion detector lighting
I am replacing my motion detector with a new one .The wires coming out of the box are white and black no ground. I hooked up the wires and the lights do not work.
Tbonehdking is offline   Reply With Quote
Old 06-24-2012, 10:07 PM   #2
Electrical Contractor
kbsparky's Avatar
Bad bulbs?
-KB
Old 06-24-2012, 10:20 PM   #3
Rewards Points: 13,300
Loose connection, is there a switch or did you leave the breaker off?
Old 06-24-2012, 10:40 PM   #4
Licensed electrician
Rewards Points: 1,294
Maybe if you tell us the connections you made someone will see what is wrong.
Old 06-25-2012, 02:28 AM   #5
Oso954's Avatar
Rewards Points: 778
What position was the "On-Time" switch in ?
Was it in the Test position ?
Oso954 is online now   Reply With Quote
Old 06-25-2012, 09:51 AM   #6
motion detector problem
I have tried it in all positions, Let it calibrate for 2 minutes. Tried putting it in manual mode. I have power to the light, it just won't turn on. the only thing I don;t have is a groung wire from the house line. Home was built in 1958
Old 06-25-2012, 09:55 AM   #7
I checked the bulbs there good, white to white and black to black
Old 06-25-2012, 02:03 PM   #8
Oso954's Avatar
Rewards Points: 778
Not having the ground wire, is generally not an issue with most motion lights.
Trying all positions is a waste of time, unless you are working after dusk. The test position is the only one that functions in daylight.
Manual mode is reset to automatic mode by daylight.
Assuming that you really do have power to the fixture and that your bulbs are either incandescent or halogen, I'd take it back to the store and ask for a replacement.
You may have a defective unit.
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 03:00 PM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 09:52 AM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 11:16 AM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 11:39 PM
Motion flood "non-standard" wiring Fishin_Man Electrical 5 01-14-2009 04:20 PM
