Old 03-04-2012, 08:36 PM   #1
Question
Motion Detector Light Problem
Im installing motion detector lights... the only thing is i want them switch activated too, so that the motion works and I can turn them on also. Which type of wire should I use? Any ideas?
Jbrown14 is offline   Reply With Quote
Old 03-04-2012, 08:39 PM   #2
Most can be activated by simply turning the switch off and back on quick. When you want to change it back to auto just shut off the power and wait 30 sec. and power it back up.
Old 03-04-2012, 08:50 PM   #3
im better of with 14-2 then?
Old 03-04-2012, 09:34 PM   #4
Electrician
SD515's Avatar
14-2 if it's a 15A circuit, 12-2 if it's a 20A circuit.
Kyle
Tags
install, lights, motion
Need Help Fixing Damp Slab Problem in Shop OlyTDI Building & Construction 10 10-30-2011 01:35 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Motion Detector For Compact Florescent Bulbs Jazan Electrical 2 10-20-2009 10:12 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
