Motion Detector For Compact Florescent Bulbs - Electrical - DIY Chatroom Home Improvement Forum
Old 10-20-2009, 06:55 PM   #1
Rewards Points: 43
The light over my garage door was hooked up to a motion detector which screwed into the socket first, before the incandescent bulb. Then I installed a new fixture which uses only a compact florescent bulb. It will not operate with the motion detector any longer. I understand that the problem is somehow related to the lag-time in using those bulbs.
Is there a way to hook up a motion detector to this new fixture? Or is there a different type of motion detector that works with florescents?
Jazan is offline   Reply With Quote
Old 10-20-2009, 07:39 PM   #2
dSilanskas's Avatar
You need a motion that works with a florescent.
dSilanskas is offline   Reply With Quote
Old 10-20-2009, 09:12 PM   #3
300zx's Avatar
Post
If you look around google it and see if you can find a better price!Then i can Here is another site $76.00 http://www.amazon.com/gp/product/B000HM5NQW
$109.91 new
Free shipping
Lamps Plus
4,195 seller ratings
White ENERGY STAR 20" 2-Light Motion Sensor Security Light
Motion detector range 180 degrees, 70 feet. Manual override. ENERGY STAR® certified. Includes two 20 watt CFL bulbs. 15" high, 20" wide. ....
Add to Shopping List
300zx is offline   Reply With Quote
Tags
florescent bulbs , motion detectors , outside lights
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Bad bulbs? Ultrarunner2017 Electrical 11 07-06-2009 10:42 PM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
Help with: Dimmable Compact Florescent Bulbs millerz1897 Electrical 19 04-06-2009 05:44 AM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
