Motion Detector 110 Hard Wired - How To Arm In Ready Mode - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 02:28 PM   #16
TTW
TTW's Avatar
This one will work for you and is pre wired.
http://www.grainger.com/Grainger/RIB...E35?Pid=search
White and black, 120 v in from sensors
Yellow and orange will switch alarm
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-07-2012, 03:21 AM   #17
Thanks, I'll get the piece and give it a shot. Will keep you posted.
marvin1944 is offline   Reply With Quote
Old 12-15-2012, 04:14 AM   #18
It worked. Make a note that if your alarm e.g bell, don't fires up, then a connection to a light fixture is necessary. My application did not require a light fixture to function. Many thanks TTW. STEPPING UP, now that I can turn on/off the system using a single pole switch, is there another way I could use a remote control device instead.
Hard wired smoke alarm in NYS ADKstorm Electrical 12 04-30-2009 09:58 PM
NEED HELP with hard wired timer to outlet puffedupseagull Electrical 4 04-24-2009 09:44 PM
Hard wired Low Voltage Transformer? VistaV Electrical 9 04-25-2008 10:04 AM
Just to confirm, no GFCI needed for hard wired pool pump..right?? Al the Diy guy Electrical 6 02-10-2008 12:28 PM
Hard wired fire alarms keeping going off sdgoss Electrical 6 11-09-2005 08:57 PM
