Most Affordable Way To Tap A Generator Into Whole Home? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2014, 12:38 PM   #1
Rewards Points: 161
Question
most affordable way to tap a generator into whole home?
After a random power outage of 12 hours last night, I was thinking of getting a portable generator to power the fridge, a few lights, furnace fan, garage door opener, and possibly 800w worth of electronics.
I have been reading about transfer switches and interlocks. What's the best way to plug in a genny to power all/some circuits of the house off of the generator about once or twice a year?
Is it OK for me to install, or would it be best to have a electrician do it properly? I was thinking this guy:
Generac 60-Amp Single-Load Manual Transfer Switch
Item #: 545630 | Model #: 6333.0
runs $100 at lowes
I do not mind 100% manual process, as i'll have to grab the genny, run the cable, plug it in, etc.
vivithemage is offline   Reply With Quote
Old 06-12-2014, 12:46 PM   #2
PoleCat's Avatar
Rewards Points: 1,638
Portable generators can only supply a very limited load. You are wanting to keep it cheap then extension cords to the critical loads is bottom dollar.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-12-2014, 12:49 PM   #3
Rewards Points: 161
I agree, but I would not mind spending $200-$300 on transfer box so I can just hook up to the whole house via one cable.
Old 06-13-2014, 12:00 AM   #4
Rewards Points: 338
vivi, a generator transfer switch won't allow you to hook up the whole house, just a few circuits (usually 6-10). An interlock will allow you to do that. There are plusses and minuses to each. See one of several discussions here and at other electrical web sites. I prefer transfer switches, but that's just me.
petey_c is offline   Reply With Quote
The Following User Says Thank You to petey_c For This Useful Post:
cj133 (06-14-2014)
Old 06-13-2014, 12:19 AM   #5
Rewards Points: 332
An interlock kit would be the most cost effective.
Sent from my SM-N900T using Tapatalk
sgip2000 is offline   Reply With Quote
The Following 3 Users Say Thank You to sgip2000 For This Useful Post:
cj133 (06-14-2014), Speedy Petey (06-13-2014), stickboy1375 (06-13-2014)
Old 06-13-2014, 04:52 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Agree. Done right it is the most cost effective way. You are looking at $200 minimum including a cord for the genset.
Old 06-13-2014, 08:16 PM   #7
Rewards Points: 332
Yep. I spent about $100 just on the interlock bracket and the inlet. Still costs less than a transfer switch. Little less convenient though.
Old 06-13-2014, 08:47 PM   #8
Rewards Points: 3,396
OP the 100 bucks you quoted is about right for a 8 circuit panel
2- 2 pole breakers
manual lock mechanism
you can add a sub panel (larger than the one from lowes) so you have more circuits to feed than just four.
additional, size of main lug panel.
feeder and feeder breaker.
crucial circuit breakers and labor.
Wire to and outlet for generator.
If you have the room in your panel and could bring your 2 pole generator breaker there. You can check here to see if they have a mechanism that will fit your panel.
They're about 150 bucks. But no need for a subpanel and all involved.
You can also refeed "everything" in your house and shed loads as needed.
http://www.interlockkit.com/index.htm
ritelec is offline   Reply With Quote
Old 06-13-2014, 08:53 PM   #9
Interlockkit.com is outrageously expensive, BUT...they have them for most panels, even older ones.
If you have a relatively recent panel the factory pieces are like $50-$75.
The Following User Says Thank You to Speedy Petey For This Useful Post:
ritelec (06-13-2014)
Old 06-13-2014, 09:24 PM   #10
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
150 bucks for a interlock kit isn't a bad price, far from outrageous... they have overhead, just like electricians... IMO, I sell them to make money, so I could care less what they charge..... Speedy, you wouldn't want Interlockkit.com telling you, you charge too much to install their product, so it really isn't fair to say they are too expensive either...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Kpack (06-14-2014)
Old 06-13-2014, 09:46 PM   #11
I totally get that they have R&D, tooling and such, but 3x the price of the competition IMO is overpriced. Especially for what you get.
Old 06-14-2014, 08:23 AM   #12
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Master Electrical Services aka interlockkit.com is here in my area.
I was told by one of the guys there that, the reason for the added cost, is for the UL listing.
Being listed is very expensive and because most manufacturers have multiple products, that cost can be spread out.
wirenut1110 is offline   Reply With Quote
Old 06-14-2014, 09:38 AM   #13
Licensed electrician
Rewards Points: 996
The last I looked they still were not UL listed. Do you know if that changed?
Old 06-14-2014, 09:51 AM   #14
Every time I read the post title (most affordable way to tap a generator into a whole home?), it reminds me of an install I just finished up.
When I walked in, there was a whip from permanently installed generator to a outdoor pool panel.
Get it?
Old 06-14-2014, 11:06 AM   #15
E2 Electrician
As far as I know, they are still not listed.
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 11:55 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
