Mortal Kombat 3 Only Running Demo - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 04:04 PM   #1
mortal kombat 3 only running demo
i have a mortal kombat 3 machine that was working fine and is set on free play but now wont take commands from the start or test button or coin switch anyone have any ideals thanx
shanebyrd is offline   Reply With Quote
Old 12-13-2011, 06:33 PM   #2
Rewards Points: 1,532
Do the wires from the test switch, the start button, and the coin switch all go to one place or to three different places on the machine chassis or circuit board?
Old 12-13-2011, 06:33 PM   #3
Try jumpering t
Old 12-13-2011, 06:34 PM   #4
Try jumpering the two terminals on the chassis to which the pair of wires from the start button are connected. If this is a circuit board, be very careful that the jumper wire does not touch anything else.
Old 12-13-2011, 07:20 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Actually....I think that is the default mode when the box is stolen...
Basement *VENTING* AND running entire new drain lines. 57_Hemi Plumbing 6 09-30-2010 09:00 PM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 09:13 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 01:48 PM
Running a generator for power outages tropic home Electrical 5 12-04-2006 08:22 PM
