More Than A Tripped Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 06:48 PM   #1
WGD
More than a tripped breaker
I accidentally cut through a lamp cord and got big spark. The outlet it was plugged into and one other stopped working. There was a tripped breaker in my box, so I flipped it back on (after unplugging the lamp of course), but I still don't have power to either outlet. The two outlets seem to be the only things on that breaker's circuit, which probably makes sense since they are the only two in an addition to the house. There is no GFI. The wires inside each outlet box look fine. What is the next thing to check?
WGD is offline   Reply With Quote
Old 07-14-2012, 07:14 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by WGD View Post
I accidentally cut through a lamp cord and got big spark. The outlet it was plugged into and one other stopped working. There was a tripped breaker in my box, so I flipped it back on (after unplugging the lamp of course), but I still don't have power to either outlet. ... What is the next thing to check?
Open up the two boxes and check all the connections...
and with a tester for proper voltage.
uh huh ...check anyway.
If the breaker is on and holding (=you've read power on the wire there) but you have NO power at either box and... and there really is no other device (GFI or other)... then you have a fault somewhere in one of your walls. You *really* don't want this to be true.
Old 07-14-2012, 11:11 PM   #3
Master Electrician
The plugs may have blew open. Check the connections with a meter as suggested, but I suspect you need a couple new receptacles or you blew apart a wire inwall.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-15-2012, 12:32 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Check the affected receptales and make sure you double check the wirenuts if they are loose the short circuit can make them more looser.
If you did have backstabbed receptales then it is a good time to move to the screw types.
Merci,
Marc
Old 07-15-2012, 07:59 AM   #5
DIY staff
Rewards Points: 7,174
Flip the breaker off and on --some need to be switched off fully before they will reset---
Old 07-15-2012, 12:26 PM   #6
Master Electrician
Now why didn't I think of that? Although the breaker shouldn't sit in the on position correctly without a reset it can still be deceiving. Good catch.
Old 07-15-2012, 01:00 PM   #7
MarginallyQualified
Maybe the OP will come back and tell us if that worked?
No power and no breaker tripped temporarily jritkes Electrical 2 06-16-2011 02:05 PM
Heat Pump trips breaker gt1935 HVAC 2 03-26-2011 11:06 PM
Lost all power and breaker not tripped avro1 Electrical 18 02-24-2011 08:57 PM
Breaker tripped after power outage. What's up? Leah Frances Electrical 14 02-12-2009 07:56 PM
Breaker tripped and won"t reset princessme Electrical 8 01-19-2009 08:10 AM
