More Than One Cable In NM Connector? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 02:20 PM   #1
Rewards Points: 862
More than one cable in NM connector?
I've got another question, kind of related to the one about the wire I posted earlier.
I've noticed that the electrician who installed the CH panel in my home ran two NM cables through some of the NM connectors.
Are there connectors designed for more than one cable, ie; is this code?
It's not that I'm going to pull them out and punch another knockout, but I am curious. The panel passed inspection.
Ultrarunner2017 is offline   Reply With Quote
Old 01-06-2009, 02:24 PM   #2
Its ok only if the clamp is rated for more than two cables, this is done all of the time. Don't worry, its perfectly fine.
rgsgww is offline   Reply With Quote
Old 01-06-2009, 02:27 PM   #3
Rewards Points: 862
Thanks for your quick reply;
It looks as though the connectors are big enough to accomodate the two cables. Nothing appears squeezed or pinched.
I don't think it would be OK in the old metallic "Romex" connectors. I have stopped using those, even though I am always very careful not to over-tighten the screws. The NM ones are cheaper too<g>
Old 01-06-2009, 02:31 PM   #4
Electrical Contractor
If they're rated you can use them.
I use two screw metal romex connectors all the time.
hpp58 is offline   Reply With Quote
Old 01-06-2009, 02:32 PM   #5
Rewards Points: 2,350
I have never checked the rating for any style of NM connector, but I have put in thousands upon thousands of both metal clamps and plastic hit-locks with two cables and never had a problem, either electrically or from an inspector.
Old 01-06-2009, 02:39 PM   #6
Rewards Points: 862
Thanks for your help guys;
I have not worked with multiple cable metallic connectors, just the ones for single cables. I guess it's pretty simple. The rating / capacity should be stated on the package.
I just bought two packages of five NM type, but not sure if they are rated for more than one cable. I was planning to use them for single cables though.
Old 01-06-2009, 03:15 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Almost all metallic clamps are rated for more than one cable..as an example
Application: Indoors Only. Fits NM Cable: #14/2, #12/2, #12/3, AWG or 2 #14/2 AWG or Flex Cord .300 to .560 inches diameter 3/8" (1/2ko). Type: Twin Screw. In a dry location, use to connect nonmetallic sheathed cable to a steel outlet box or other metal enclosure. Miscellaneous: 3/8" size fits 1/2" knockout.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-06-2009, 05:48 PM   #8
Rewards Points: 862
The ones I have been using have the top half of the clamp bend downward, instead of upward as the one shown. Are the clamps reversible?
For the non-metallic ones, is there a specification that says they are good for more than one cable? The ones I bought at HD yesterday don't list any cable occupancy specs.
Old 01-06-2009, 09:30 PM   #9
Rewards Points: 506
Send a message via AIM to theatretch85
There should be something on the outside of the package that indicates what you can put in the connector safely.
Take a look at the link below, it shows the 3/4" version of the Arlington romex connector which indicates "1 or 2" cables:
http://www.foxelectricsupply.com/con...ductNo=ARLNM95
Hope this helps!
theatretch85 is offline   Reply With Quote
Old 01-07-2009, 07:25 PM   #10
Rewards Points: 862
Hope this helps!
Thanks for the link. I'll try those next. Today, I rewired some very old BX in my basement, and used this one for the NM cable.
I like them, but the Arlington looks simpler, since you don't need to use any tools to close them.
Old 01-07-2009, 09:06 PM   #11
Learning by Doing
Leah Frances's Avatar
I would just like to curse the heart of the electrician who wired my breaker panel. Every single knockout had at least two NM running through them. That combined with the bird's nest inside the box made tracing the circuits a - because, of course, none of them were properly labeled.
Is there any reason not to knock out more knock-outs (other than the minor cost of the NM connectors)?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-07-2009, 09:28 PM   #12
Res Ipsa Loquitur
Probably just saving time in having to do this as well as the labor/effort to run single cables per knockout. My original 150a Murray panel which I just replaced was put in in 1971. The electrician used the larger knockouts like 1" or so and placed about 3 or 4 cables in each. My guess is that it was entirely legal at the time as it was inspected & approved by a reputable certified agency in my county.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-07-2009, 10:17 PM   #13
Learning by Doing
And this was after I removed about 10 feet of decommissioned circuits that were just left tangled up in the box. All of the NM connectors on the right side are doubled up.
Old 01-08-2009, 01:05 AM   #14
kbsparky's Avatar
....Is there any reason not to knock out more knock-outs (other than the minor cost of the NM connectors)?
Not enough knockouts, in many cases...
Old 01-08-2009, 07:20 AM   #15
Rewards Points: 862
The electrician who installed my new panel (200A CH), he not only doubled up on connectors / knockouts, but also used several shared neutrals in runs from the panel to J-boxes just above it to connect with wiring that would not reach the new panel.
He used 14/3 or 12/3 cable then split the circuits in the J-box.
I believe, but I am not sure he has these circuits on opposite legs. I need to check this out next time I go in there.
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 10:04 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 09:00 AM
SS flexible connector with nut? oldnightnurse Plumbing 38 05-21-2008 07:40 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
