More Than Just A ? On Grounding Size For Sub Panel. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 08:58 PM   #1
Rewards Points: 163
More than just a ? on grounding size for sub panel.
Hi guys,
I've read through a bunch of posts and found a lot of good info, but I didn't see this answered directly.
I'm running a 40amp sub panel in my attached garage using #6 in conduit. I'm not going all the way back to the main panel with it though. About 3/4th of the way across the basement I'm tying into an abandoned electric range feed, which is a 6/3 NM w/ground (all copper). I threw up a Milbank and brought in my #6's and the 6/3, and tied them in with a Polaris block.
My question is what size wire do I need to bring back from the sub panel to where I'm tying in with the 6/3? One of the electricians on a job I'm at said I should run #8 for the ground. Does it need to be that big? I've got the #8 so it's no big deal, but what if I ran the 6/3 w/ground all the way between each panel? The solid wire ground in that NM looks pretty small. Could I run the same size solid ground?
More of a theoretical question I suppose.
Thanks for any info.
Eric
52Caddy is offline   Reply With Quote
Old 05-27-2010, 09:05 PM   #2
Master Electrician
Rewards Points: 3,874
6-3 wg NM contains a #10 equipment ground. There is no reason to use a larger size given the the 40 amp circuit breaker.
Don't forget to bond the j-box if it is metallic.
brric is online now   Reply With Quote
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Wire size for Sub panel DaleB Electrical 24 01-18-2015 01:52 PM
need to know what size sub panel to get italy92530 Electrical 23 01-15-2010 09:56 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Cable Size for Sub Panel vs chart jamiedolan Electrical 5 11-09-2008 01:30 PM
