1 : What's normal elevation for running wires horizontally in a kitchen wall? Would you rather run them overhead (more wire)?
2 : Is there anything wrong with drilling a wire around a corner, or would it be better to again run overhead (more wire)
3 : is it ok to have multiple circuits going through the same hole? I'm assuming so because I have lots of existing wires this way.
I'd probably nitpick myself less, if I wasn't a plumber. It makes me think about so many different things before I actually do them, which I guess isn't bad.
:whistling2:
:whistling2:
