More Piddly Questions. Ugh. . . . . - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 08:57 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
More piddly questions. Ugh. . . . .
1 : What's normal elevation for running wires horizontally in a kitchen wall? Would you rather run them overhead (more wire)?
2 : Is there anything wrong with drilling a wire around a corner, or would it be better to again run overhead (more wire)
3 : is it ok to have multiple circuits going through the same hole? I'm assuming so because I have lots of existing wires this way.
I'd probably nitpick myself less, if I wasn't a plumber. It makes me think about so many different things before I actually do them, which I guess isn't bad.
Journeyman Plumber
Old 01-29-2012, 09:15 PM   #2
Licensed electrician
Rewards Points: 1,508
I try to avoid the heights where the cabinets will get screwed to the wall. Less chance of damage.
Around the corner or overhead is fine. Some may have trouble getting the cable through the corner method.
Multiple cables can go through the same hole. I normally limit it to 2-3 cables in a 3/4" hole.
Old 01-29-2012, 09:15 PM   #3
Master Electrician
Rewards Points: 3,828
Waist high, easier to drill and pull.
No
Yes
brric is online now   Reply With Quote
Old 01-29-2012, 09:19 PM   #4
Doing it myself
Alan's Avatar
Multiple cables through a hole still ok if they are different circuits?
Journeyman Plumber
Old 01-29-2012, 09:23 PM   #5
No problems with more than one circuit through the holes.
Old 01-29-2012, 09:24 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
Not a problem.
Old 01-29-2012, 09:26 PM   #7
Doing it myself
Alan's Avatar
Thanks guys
Hope your upcoming week goes well.
Journeyman Plumber
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 12:59 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
