More Grounding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 03:36 AM   #1
Rewards Points: 33
More grounding question
In the main panel, it used to have ground connected to cooper water pipe in front of my home. I added two ground rod about 8 feeds apart and connect this to the main panel.
Is it ok to leave the old ground which connects to the water pipe or should I disconnect it?
Can I repurpose the ground wire which runs between main panel and water pipe? For example, to ground other sub panel using split bolt? I have one sub panel which has *NO* ground.
Thanks a lot.
cfreak is offline   Reply With Quote
Old 09-17-2011, 03:53 AM   #2
Code05's Avatar
Rewards Points: 1,104
Leave the water ground.
No you cannot use it to ground a sub panel.
Sub-panel has a 3 wire feed? Pipe or cable?
Code05 is offline   Reply With Quote
Old 09-17-2011, 04:06 AM   #3
Rewards Points: 33
It has 3 wire feed (2 hot, 1 neutral, no ground) through metallic conduit.
Do I have to pull a new wire? oh... I should be able to use the conduit for grounding.. Am I correct?
Old 09-17-2011, 04:37 AM   #4
Code05's Avatar
Yes. What type of metal conduit?
The Following User Says Thank You to Code05 For This Useful Post:
cfreak (09-17-2011)
Old 09-17-2011, 09:04 AM   #5
Licensed electrician
Rewards Points: 1,030
A metallic water line in direct earth contact for ten foot or more would be your primary electrode. The rods would be a supplemental electrode.
cfreak (09-17-2011)
Old 09-17-2011, 09:40 AM   #6
Rewards Points: 150
Thanks a lot.
Where is the sub panel located?
Sunny B. is offline   Reply With Quote
Old 09-17-2011, 09:45 AM   #7
Master Electrician
Rewards Points: 3,684
The metallic conduit between the panels is the equipment grounding conductor.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
cfreak (09-17-2011)
Old 09-17-2011, 01:45 PM   #8
Rewards Points: 33
@Code05 - It should be RMC. It is threaded but it's also rustted.
@Sunny B. - The sub panel is in the garage of the same building.
Is there an way to connect ground bar to this pipe? It seems that the panel is color coded. I check by ohm meter between the box and the conduit and it seems to be not connected.
Old 09-17-2011, 04:43 PM   #9
Code05's Avatar
If the conduit to panel connection is not real good, you can use these.
cfreak (09-17-2011)
Old 09-21-2011, 03:56 PM   #10
Rewards Points: 33
How do you call this? Do you know any online store sell it? (I can only find Halex ground clamp)
I cannot find it at HomeDepot.
Old 09-21-2011, 04:07 PM   #11
Code05's Avatar
http://www.garvinindustries.com/Elec...Collar/GCHK250
Grounding question for subpanel mn1247 Electrical 26 09-19-2011 11:41 AM
Outlet grounding question handyd123 Electrical 5 11-28-2010 03:15 PM
Grounding a Square Box <--newbie question dgates12 Electrical 20 01-06-2010 07:02 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 05:14 AM
