More Flood Light Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 08:55 PM   #1
Rewards Points: 165
More flood light help
As in my previous thread I mentioned I am running some new wiring for floodlights. I would like to know if I shoud run 12/2 or 12/3 for the lights. They will only be controlled by one switch. If i run the 12/3 for future proofing, can I just put a wire nut on the red conductor at each end of the cable, ie box and fixture?
chronojosh is offline   Reply With Quote
Old 03-13-2011, 09:27 AM   #2
Just call me Andrew
Rewards Points: 1,020
You can certainly put the extra conductor in and just cap it at both ends.
By "future proofing" do you mean in case you want to add a second switch to control these lights? Depending on how you wire it, you probably will not even need 12/3 between the switch and fixture. You would likely need 12/3 between the two switches, and 12/2 between the switch and the fixture.
Andrew
secutanudu is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 12:23 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 10:58 AM
