More Faucet/water Shocks - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 11:50 PM   #1
More faucet/water shocks
Hi all,
I have read a few posts here about others having problems with receiving a shock while touching the faucet or water from the faucet in certain rooms. Today I experienced this problem in my kitchen. I was able to narrow the problem down to one breaker on my box, specifically one set of outlets. My question is can a faulty outlet cause this to happen?
I currently have the breaker in question flipped off until I can replace the outlet and see if that fixes the problem. There haven't been any changes to the electrical or plumbing in quite a while. This happened completely out of the blue.
Any advise that you might have would be greatly appreciated.
Jess
Jelisa08 is offline   Reply With Quote
Old 04-16-2012, 12:41 AM   #2
Rewards Points: 1,192
Electric water heater?
bobelectric is offline   Reply With Quote
Old 04-16-2012, 01:04 AM   #3
No, gas water heater.
Old 04-16-2012, 01:29 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,990
Exactly what were you touching? Have you used a meter to measure voltages anywhere? While it is possible for the plumbing to become electrified, it is more common for another surface to be electrified and the plumbing to provide a return path. Were you touching a metal object or appliance other than the plumbing when you got shocked?
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
zappa (04-16-2012)
Old 04-16-2012, 01:42 AM   #5
I haven't used a meter yet. I was only touching the faucet or water when I was being lightly shocked, just as I usually would when washing my hands, etc. there wasn't any other metal in the area. The house is on a raised foundation and I was standing on tile with slippers on. I was able to persuade my unlucky friends to also touch the faucet and water and they had the same light shock. My refrigerator is on an outlet on the other side of the room and has a copper line for the ice maker. First I thought that might be a problem so I unplugged the fridge. However, I was still shocked after unplugging it. So I decided to trip the breaker for this outlet and I was no longer shocked. Could it be as simple as a faulty switch or is this going to get complicated?
Old 04-16-2012, 02:40 AM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is your disposal or dishwasher fed by that circuit by any chance?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-16-2012, 02:45 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
My advice is...forget about trying to troubleshoot this over the internet. Call a local electrician.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
mpoulton (04-16-2012), plummen (04-16-2012)
Old 04-16-2012, 03:07 AM   #8
Unfortunately they are not fed by that circuit. The circuit that garbage disposal and dishwasher are fed by are still on and no problems.
Old 04-16-2012, 03:10 AM   #9
plummen's Avatar
So much for simple fix,what is fed by that circuit?
Old 04-16-2012, 03:23 AM   #10
Thumbs down
The fridge (with a copper water line for ice maker), microwave, electric starter component of gas stove, and my desktop computer that shares the other side of the wall.
I have the fridge on an extension cord right now and no shocking is occurring. In fact the only time shocking has occurred is when that circuit is on, even with the fridge unplugged.
Old 04-16-2012, 03:28 AM   #11
plummen's Avatar
I wonder if it couldnt be a problem with the stove like an open neutral feeding back through the gas line and being picked up by copper water lines?
Old 04-16-2012, 03:32 AM   #12
Old 04-16-2012, 03:36 AM   #13
plummen's Avatar
Originally Posted by bobelectric View Post
Bad compressor in fridge.Leaking .
That was another thought,but he said fridge was unplugged and still causing problem.
That leads me to lean towards the stove gas line being mechanically bonded to plumbing system through water heater as a starting point anyway.
Old 04-16-2012, 03:38 AM   #14
plummen's Avatar
Id check between the power cord for ignition/timer on stove and the metal gas at the stove for continuity to eliminate it from picture.
Old 04-16-2012, 03:59 AM   #15
thank you for the ideas. I will check the stove out in the morning. Unless someone else has another idea and I don't have luck with the stove, I might have to bow out and call a professional at that point
1994 xj6 Jaguar, rear shocks r/r edselsouth1 Automotive Repairs 0 02-24-2012 10:38 PM
97 olds shiloutte air shocks running on 4just1don Automotive Repairs 6 02-01-2012 06:45 AM
Do yellow dishwashing gloves protect against shocks? mike932 Electrical 45 05-20-2011 06:54 PM
static shocks oldrivers Electrical 6 02-05-2010 10:45 AM
Shocks in House nixonj63 Electrical 20 07-19-2008 01:06 PM
