Modular Receptacle System - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 06:48 PM   #1
Structural Engineer
Has anyone here had any experience using "Lev-loc" receptacles from Leviton? It seems like and interesting concept, but I wanted to here from someone who has actually used it. Did you find it had any advantages over traditional receptacles when it came to typical use?
wildcat is offline   Reply With Quote
Old 04-15-2009, 11:09 PM   #2
I haven't used these but it seems to me that it would not save time or money considering how often receptacles actually need to be replaced.
hayewe farm is offline   Reply With Quote
Old 04-15-2009, 11:19 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yep.
The 660,000 sq ft hospital I am currently working on is using them. I don;t see any real benefit except for one. You can unplug the things while the circuit is hot with no danger of shock.
I do not believe they save much time. It does remove the need to put the wire on the screw terminals but that is it.
I don't see it as a time saving when needed to R and R a recep (because it saves very little) but it allows you to work hot, and be safe. It is important you leave power on in a hospital.
Old 04-16-2009, 04:51 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
For folks who have not heard of "LEV-LOK"
http://www.leviton.com/OA_HTML/ibeCC...minisite=10026
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-16-2009, 10:18 PM   #5
Electrician
Rewards Points: 802
I can't see these saveing any time, anyone with experience can through a plug on very quickly. They would be even more of a pain when you had to connect 4 wires, then you would have to make pigtails on everything. I will keep wrapping the wire around the screw.
darren is online now   Reply With Quote
Old 04-16-2009, 10:27 PM   #6
Well, in a hospital you can't always shut a circuit off to replace a receptacle
But how many times do they need to do that?
I guess if the price isn't that much more it would be an added convienence
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 05:24 AM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 10:06 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
