Modular Home Electric - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-09-2013, 10:54 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Your panel will supply 24000 watts for home useage. Is your heat electric?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-09-2013, 11:52 PM   #17
Electrical Contractor
kbsparky's Avatar
Originally Posted by Stubbie View Post
.... Is your heat electric?
The OP stated he has oil heat.
-KB
Old 02-09-2013, 11:59 PM   #18
We ran a new line to the garage to free up the 100 amp panel in the home, and for future use in the garage, air compressor, etc. My Father in law owns a company that goes into foreclosed plants and companies and buys up company inventory for liquidation. I had the copper wire, conduit and fittings, square d panels and breakers available at no cost. Unfortunately the wire was #4 copper on a 500' roll. Material was free, only had to pay labor. I saved what was left of the wire, and have a 8 space square d QO main lug sub panel with a 50 amp breaker for the stove, 30 amp for the dryer, and 4 20 amp breakers for washer and spares. I also have 1 1/2" or 1 1/4" conduit to run from pole to sub panel which I intended to mount near the 100 amp main box in the home. Like I said, we're having no breaker issues currently, but I have the material so why not use it. I figured we'd run a line for the AC unit from the sub panel also. I have a 100, 70, and 60 amp breaker also for the 200 amp main breaker box, so the sub panel could be fed by any of them. I was leaning toward the 70 amp.
ricbrk is offline   Reply With Quote
Old 02-10-2013, 12:13 AM   #19
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
This isn't the news you want to hear, but the entire install of the new subpanel is illegal if the garage is attached. The only way to make it legal is run a larger feed to the home.
Old 02-10-2013, 12:46 AM   #20
UAW SKILLED TRADES
Stubbie's Avatar
Ahhh missed it ...post #6.
Stubbie
Old 02-10-2013, 07:31 AM   #21
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You can only run one feed of power to a structure.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-10-2013, 07:35 AM   #22
Maybe I'll just leave matters alone then since no breakers are tripping, and start looking for #2 copper to replace the #4 currently feeding the existing panel. I'll see our local code enforcement officer at church today. I'l explain the situation to him and get some imput. At least I didn't install the panel and find out it's illegal. Thanks for the advice.
Old 02-10-2013, 09:21 AM   #23
rrolleston's Avatar
Running #2 would be a lot of work for the amount of extra capacity it would get you. I think you could go 3/0-3/0-1/0-#4 CU and have 200 amps. But since you are not having trouble and are not planning to add anything else I would leave it alone.
I think if I had trouble I may also think about switching water heater and range to gas.
Old 02-10-2013, 12:24 PM   #24
UAW SKILLED TRADES
Stubbie's Avatar
That's a good idea to visit with the local inspector. To change to a larger service to the house is more complicated and costly than you may think unless you can get the materials through your dads business. You also may be forced into a reclassification of your home.
Just something to think about as I don't know what service combination equipment you have at the meter. You might run by the inspector if he would allow feed thru lugs installed in the service equipment at the meter (it may already have them). Reason I say this is if you ever upgrade you will not be able to connect that larger feeder for 200 amps to the existing service equipment without feed thru lugs. You may have to change out what you have for service equipment.
I actually do not think you will have any issues staying with the 100 amp service since what you listed does not include electric furnace.
Stubbie
Old 09-26-2014, 10:50 AM   #25
Rewards Points: 37
First of all all you care about designs and appliance to where you keep it safely or attatched to modular kitchen for better purpose.
garykerr is offline   Reply With Quote
The Following User Says Thank You to garykerr For This Useful Post:
Anti-wingnut (09-29-2014)
Old 09-26-2014, 09:59 PM   #26
dmxtothemax's Avatar
Rewards Points: 5,102
Good idea !
Where do all these three feeds come together
House 100A
Garage 60A
Well 30A
Whilst the house 100A is close to max
The chances of everything being on at the same time is very slim
So if no breakers are tripping your good.
dmxtothemax is offline   Reply With Quote
Old 09-27-2014, 10:49 AM   #27
Licensed electrician
Rewards Points: 1,266
Another zombie thread.
jbfan (09-27-2014)
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
mobile home half electric outlets not working...please baby327nd Electrical 11 02-07-2013 11:51 PM
modular home builders in midwest that will do custom designs 7777 Building & Construction 2 01-22-2013 03:29 PM
Residential air handler in modular home. Doc Holliday HVAC 31 04-23-2012 09:11 PM
Converting Electric home to Gas Rick2003 Plumbing 1 04-18-2011 12:14 AM
