Modify A Breaker Panel Cover. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 11:27 PM   #1
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Modify a breaker panel cover.
I am replacing a feed through breaker panel the bus bar and breaker was inverted but the main breaker is up and down with on being down and I also noticed that the plastic in the back that holds the bus bar is cracked.
I bought a newer model from the same manufacture that has a much better design and a better main breaker. But unlike the one I already have when you invert it the breaker slots don't line up and cover does not fit properly.
I was thinking about just cutting out the center where the breaker slots are. I measured and if I cut it just right all I have to do is turn it over and it will line up just have to bolt or weld it in place. Would this be legal
I also thought about putting the panel the way it came and feeding the bus bar hot and keeping the panel under the 6 throw rule. Or would that not work because I am using feed through. There will be 4 double pole breakers and the one main that feeds a sub panel.
I really hate the cheap design of this panel.
I plan to replace it with this.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-10-2012, 09:11 AM   #2
I=E/R
a7ecorsair's Avatar
Are you trying to use the old cover on the new panel?
a7ecorsair is offline   Reply With Quote
Old 03-10-2012, 09:20 AM   #3
Licensed electrician
Rewards Points: 1,234
I think I would just change out the whole panel. No need to rework the old cover or wonder if the inspector will approve it. Also the time and labor saved by not reworking the cover.
Old 03-10-2012, 09:41 AM   #4
rrolleston's Avatar
My plan is to change out the whole panel. I have the new panel and I can invert the bus but the cover won't fit after. I thought it would be like my current panel but not so lucky.
Old 03-10-2012, 12:04 PM   #5
Master Electrician
Rewards Points: 3,746
Looks like a 1 hour change out with the small number of conductors entering the old panel. I am wondering how you got a 3r, non-reversible panel with a main in the wrong orientation.
brric is offline   Reply With Quote
Old 03-10-2012, 12:06 PM   #6
Will the breaker operate so that up is on? If it operates horizontally you would flip the can and cover,
Old 03-10-2012, 12:08 PM   #7
Master Electrician
Jim, how do you flip a 3r panel?
Old 03-10-2012, 12:12 PM   #8
Did not look at it that close.
Wait, maybe the panel is meant for Australia?
Old 03-10-2012, 12:15 PM   #9
Master Electrician
I guess you could flip it but the cover would be quite unhandy.
Old 03-10-2012, 02:06 PM   #10
rrolleston's Avatar
Seems I have to modify the breaker panel anyways when I put the Siemens interlock kit I need for my generator.
Old 03-10-2012, 02:25 PM   #11
rrolleston's Avatar
Only thing that sucks is I had the power turned on so I have to have the meter pulled to make the switch.
Old 03-10-2012, 02:53 PM   #12
Master Electrician
Don't know how it is in your area but we pull meters all the time to do service changes or modifications.
Old 03-10-2012, 03:43 PM   #13
rrolleston's Avatar
I will most likely pull it and then contact them and they just add a new seal. This meter socket is only about 12 years old and was just pulled to turn the power on so not much worry. I do worry when pulling those really old meters though.
Had to pull one to replace a main breaker in the middle of the night once. Safety shield and heavy rubber gloves with inserts and hope for the best.
Really hope I never have one fall apart on me.
Old 03-10-2012, 06:02 PM   #14
Master Electrician
Surely you know to shed the building load before pulling the meter.
Old 03-10-2012, 06:59 PM   #15
rrolleston's Avatar
Yes I always make sure and double check with volt meter. Have had to turn off all breakers before when a main would not turned off.
Nothing plugged in there though so no draw.
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
Square D panel cover dougie-r Electrical 0 04-12-2011 10:40 PM
New Breaker Panel Questions AvalonGirl Electrical 10 06-02-2010 11:20 AM
Hot water flate rate conversion to breaker panel curlycord Electrical 1 05-06-2009 08:24 PM
Portable breaker panel? minameismud Electrical 15 02-24-2008 01:57 PM
