Modern Dimmers ? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2012, 11:29 AM   #1
Rewards Points: 222
modern dimmers ?
i am going to be putting 2 ceiling fans in a newly finished complete gut room.
i want dimmers on the new ceiling fans, that i have yet to buy.
what i want to know is : how do i go about buying compatible dimmers, fans and bulbs ?
i ask, because i have had issues with this in the past.
Fix'n it is offline   Reply With Quote
Old 12-25-2012, 11:36 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I would buy a fan that uses regular Edison base lamps. Then decide whether you want incandescent, CFL or LED lamps. Make sure the ones you buy are dimmable (if CFL or LED). Wire a hot and neutral to the switch box and a 3 wire cable up to the ceiling box. Buy a dimmer compatible with the type lamps.
Coastal South Carolina
Old 12-25-2012, 11:55 AM   #3
Electrical Contractor
kbsparky's Avatar
Something like this would be appropriate:
Edit to add: You would need one of these for EACH fan.
-KB
Old 12-25-2012, 12:44 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Here is a good reference on the different types of dimmers available...
http://www.lutron.com/en-US/Products...sSwitches.aspx
Old 12-25-2012, 12:52 PM   #5
Rewards Points: 320
You need a switch like kbsparky posted. You don't use a dimmer on the fan motor. You need a fan speed switch for fan speeds and a dimmer for the light kit on the fan.
teamo is offline   Reply With Quote
two dimmers, 1 for spots 1 for chandelier help Nessa Electrical 9 02-01-2012 12:34 AM
Help!! So confused on wiring dimmers! Skylaa Electrical 19 12-12-2011 10:59 PM
Help with Lutron Maestro IR dimmers jkr77 Electrical 5 02-28-2011 09:38 AM
Too many dimmers? MikeVila Electrical 6 11-30-2010 07:46 PM
leviton vizia dimmers Thomas Rice Electrical 2 03-14-2009 07:16 AM
