-   -   modern dimmers ? (http://www.diychatroom.com/f18/modern-dimmers-167335/)
Fix'n it 12-25-2012 10:29 AM
modern dimmers ?
i am going to be putting 2 ceiling fans in a newly finished complete gut room.
i want dimmers on the new ceiling fans, that i have yet to buy.
what i want to know is : how do i go about buying compatible dimmers, fans and bulbs ?
i ask, because i have had issues with this in the past.
rjniles 12-25-2012 10:36 AM
I would buy a fan that uses regular Edison base lamps. Then decide whether you want incandescent, CFL or LED lamps. Make sure the ones you buy are dimmable (if CFL or LED). Wire a hot and neutral to the switch box and a 3 wire cable up to the ceiling box. Buy a dimmer compatible with the type lamps.
kbsparky 12-25-2012 10:55 AM
Something like this would be appropriate:
http://images2.cableorganizer.com/lu...FSQH-WH_sm.jpg
Edit to add: You would need one of these for EACH fan.
ddawg16 12-25-2012 11:44 AM
Here is a good reference on the different types of dimmers available...
http://www.lutron.com/en-US/Products...sSwitches.aspx
teamo 12-25-2012 11:52 AM
You need a switch like kbsparky posted. You don't use a dimmer on the fan motor. You need a fan speed switch for fan speeds and a dimmer for the light kit on the fan.
