Modern Apartment/ Spots Are Flickering - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2008, 08:36 PM   #1
Unhappy
modern apartment/ spots are flickering
i live in a fairly new apartment in dublin, never had any problems with lights wireing or anything before,
just got six spots/downlights with the transformer bits and a dimmer switch put in, they work fine when on full power but they flicker up and down when they are dimmed???
i watched how they were put in and it all looked very easy!!
there used to be one light in the middle of the room, witch the guy took out and used this as the power for all the lights.
he drilled a few holes, feed the wire through, connected it to the tranformer then to the spot. (done this for all of them)
he then put a dimmer were the switch used to be. (simple i thought)
turned them on, wizzed then up and down a few times and left on full power. job done
how can i stop them flickering when dimmed as this is causeing me some consern!!
Thank you for any help you can give
graham in dublin is offline   Reply With Quote
Old 05-15-2008, 08:40 PM   #2
what type bulbs? what kind of dimmer? did dimmer come with lights or afterthought? flickering like you describe may be lack of proper voltage needed to ignite gas in bulb, the dimmer may be low quality and have loose contacts at the bottom end of the range, etc.,
steve f is offline   Reply With Quote
Old 05-15-2008, 08:46 PM   #3
im not sure, the dimmer is plastic, and i think the lights are 50watt each
Old 05-16-2008, 08:36 AM   #4
joed's Avatar
Rewards Points: 13,728
The lights aren't CFL are they?
Old 05-16-2008, 11:30 AM   #5
this type
modern apartment/ spots are flickering-guns.jpg
Tags
downlights , flickering , problem , spots
texture on wall vs. spackled spots diylady Painting 9 12-19-2007 02:01 PM
What is apartment grade carpet? darsunt Flooring 4 06-05-2007 05:50 AM
painting over spots created by painters putty azalee Painting 4 04-05-2007 10:56 AM
Garage Apartment LoriMD Remodeling 1 01-17-2007 08:30 PM
