Moble Home Service - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 09:04 PM   #16
Rewards Points: 512
Originally Posted by k_buz View Post
The POCO usually runs the direct burial all the way up the pole protected by a plastic channel.
Not here. POCO ends at weatherhead (which I'm not using in this case, but then I reckon they end at the meter).
Old 11-07-2012, 09:07 PM   #17
Rewards Points: 512
Originally Posted by jbfan View Post
Here we don't worry about snow, so this may not work for you.
Meter base centered about eyeball, with a mast up the pole to connect to the poco lines.
A short nipple from the bottom of the meter base to the diso, then out of the disco under ground to the panel.
Snow can be a big deal here.
What about the wire? Do I need to feed 4 through there? SER OK, or is that to be used above ground only?
Old 11-07-2012, 09:08 PM   #18
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Ok, pictures won't work the way I want them to.
In order to come into the top of the meter you have to use a hub and a threaded connector.
The threaded connector could either be for conduit or SE cable.
The POCO will usually run individual wires down the pole protected by a plastic channel. They won't run SE cable. They won't run pipe/pvc. You could run pipe/pvc up the pole with a weather head and they can connect to that. That might be your cheapest option, but might look a little unsightly.
The POCO's other option would be to run their wires all the way down the pole into the ground then back up into the bottom of the meter. The problem with that is that you will have the disconnect directly below the meter and you won't have a way to install a chase for them to run their wires back up.
I think you are better off building some sort of mount other than the pole and either mount the meter and disco side by side or ask for a meter main combo.
The Following User Says Thank You to k_buz For This Useful Post:
sirsparksalot (11-07-2012)
Old 11-07-2012, 11:16 PM   #19
Rewards Points: 512
I think I see what you're seeing, k, thanks. I know what you mean by the plastic channel. Two followups:
POCO requires using their meter bases, and I'm not sure they'll go w/ a combo, but I could ask them, I guess.
Still, I would need to provide them a way to attach to the meter, correct?
EDIT: On the other hand, why couldn't they just run their wires directly to the top of the meter socket?
Old 11-07-2012, 11:29 PM   #20
k_buz's Avatar
There is no connector for their wires that I know of. They will use three individual conductors, not conduit or cable. You will need to provide some sort of chase to protect the POCO's wires if they go underground. Your POCO will tell you what you need for that.
If you can live with the looks of it, I think I might go with a mast coming out the top of the meter socket with a weather head. Picture your typical overhead service. Keep in mind that you will need 2 ground rods for your main disco, and you will need two more at the house if the meter socket isn't attached to the house.
You could see if its legal to mount the socket on the house since you have to rerun the wire anyway. I will check my code book to see if the NEC says anything about that.
Old 11-07-2012, 11:32 PM   #21
Rewards Points: 512
OK, I think I'll look into the weatherhead idea.
Now,
Do I need to run a 4th wire underground to the house? THHN? THWN? In pipe or direct burial?
Old 11-07-2012, 11:36 PM   #22
k_buz's Avatar
Yes you will and I suggest you dig (carefully) directly next to the existing wires or you run the risk of failing due to the circuit conductors not being run together.
Since you already have URD installed, I would match that.
Old 11-07-2012, 11:54 PM   #23
" Euro " electrician
frenchelectrican's Avatar
K_buz.,
Let you know it is not legit to mount the meter socket on the mobile home unless it have basement or fully perament set up then it can go up the house ( a instering part that the meter itself will NOT touch the perament Mobile Homes )
It will not say much in NEC but NESC or POCO regulations will mention that clear.
I am not sure that mention in Art 500 but I don't recall the excat number but I know it is in there somewhere in that part.
Merci,
Marc
Old 11-07-2012, 11:57 PM   #24
k_buz's Avatar
Thanks, I didn't see that, but in the back of my head I assumed that was the case. I will look more carefully tomorrow.
Old 11-08-2012, 09:41 AM   #25
Rewards Points: 512
I still don't know what kind of disco box I need at the pole. Should it be a switch? fused? unfused? a box with 6 breakers?
Help?
Old 11-08-2012, 12:46 PM   #26
Licensed electrician
Rewards Points: 1,750
Your power company should have an approved equipment list of sockets and/or socket panel combinations.
The means of disconnect should be at the pole. Any panel downstream would be wired with 4 wires.
sirsparksalot (11-08-2012)
Old 11-08-2012, 01:31 PM   #27
Rewards Points: 3,256
Help?
Ask if they will approve a meter main with feed through lugs, purchase it yourself, and have them install it.
zappa is offline   Reply With Quote
The Following 2 Users Say Thank You to zappa For This Useful Post:
jbfan (11-08-2012), sirsparksalot (11-08-2012)
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 08:03 PM
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
Running power to small barn in VA from home service 350' ribertgropius Electrical 9 06-12-2010 02:18 AM
Cost to run electric service to home 500 feet away skinnersone Electrical 2 08-26-2007 04:07 PM
