Moble Home Service - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 07:24 PM   #1
Rewards Points: 512
Moble Home Service
I've got a mobile home that needs the meter base and a disconnect at the pole. Currently, the wires have been cut (by POCO, I guess), both at the top of the pole (Overhead service), and at the location where the last meter and disconnect were (I hope they're long enough to reach inside the Main Disco-forgot to check that).
What do I need as a Main Disconnect at the pole? MLO? Main Breaker? The panel inside the house has a 200a Main (Cutler Hammer), and will be the subpanel.
The wires going to the panel is underground and already run (3 #4 AL).
Here are some pics.
Old 11-07-2012, 08:05 PM   #2
Rewards Points: 512
Hmm, I meant 3 #4/0 wires to the panel in the Mobile Home
Old 11-07-2012, 08:08 PM   #3
capacity of 4/0 thhn in conduit is 205 amps, might be thwn which is 180
tduncanlu1077 is offline   Reply With Quote
The Following User Says Thank You to tduncanlu1077 For This Useful Post:
sirsparksalot (11-07-2012)
Old 11-07-2012, 08:11 PM   #4
Rewards Points: 512
Originally Posted by tduncanlu1077 View Post
capacity of #4 thhn aluminum in conduit is 75 amps. if you want 200 amps that's a 3/0 copper thwn or thhn
Yeah, I meant 4/0 Aluminum, Sorry.
Old 11-07-2012, 08:16 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
If the first disconnect is at the pole you need a 4 wire feed to the sub.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 11-07-2012, 08:22 PM   #6
Rewards Points: 14,312
Not sure how it works there but here your going to need a permit. Our power company comes and puts in the meter base, but will not install the meter until it's all inspected.
My building inspector would not give you a C/O until you took care of that front step.
Needs a stoop or deck not a set of steps.
Old 11-07-2012, 08:23 PM   #7
that's right, is the pipe is full you may have to get copper or a larger size conduit to fit the #6 copper or #4 aluminum grounding conductor
Old 11-07-2012, 08:33 PM   #8
Rewards Points: 512
Yes, the permit will be coming, and the POCO supplies the Meter Base, but I'm responsible to put in the disconnect and the base at the pole.
Now, if I need to run 4wire from the pole to the panel, I will, but I'm just trying to figure out what I'll need.
Old 11-07-2012, 08:40 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you have to run a new underground, I would install a new place to mount the meter and disconnect. I don't see a good way to mount both to the pole to get the wires to run into the meter. I guess you could run a mast up out of the meter base with a weather head, then come out the bottom of the meter to the disconnect, but you are running the slight risk of snow build up on the disco.
Let me qualify this by saying that I haven't done much mobile home work, so someone else might have a better way to do it.
The Following User Says Thank You to k_buz For This Useful Post:
Old 11-07-2012, 08:50 PM   #10
Rewards Points: 512
What are you seeing that's a problem, k? Are there height requirements for the disconnect?
What I was planning on doing, was installing the meter at 5', then the disco below that.
I mean, in the 2nd pic, you can see the laterals going to the panel. I don't know if they're ran in conduit or not.
It looks as though the POCO is coming to the top of the pole and down to the meter. How would you "move", or install a "new pole" for just the meter and disco? Abandon that pole completely? POCO would then run to the new pole?
I don't really see a problem using the existing pole, but then I'm not a pro.
Old 11-07-2012, 08:51 PM   #11
Rewards Points: 512
say who? What do you mean?
Old 11-07-2012, 08:54 PM   #12
I would think those wires would need to be run in PVC where there againt that pole to protect them.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
sirsparksalot (11-07-2012), Speedy Petey (11-08-2012)
Old 11-07-2012, 08:58 PM   #13
k_buz's Avatar
This is a hard scenario to explain in words...I will try to draw up a quick picture to help explain the problem I am envisioning.
Old 11-07-2012, 08:59 PM   #14
k_buz's Avatar
The POCO usually runs the direct burial all the way up the pole protected by a plastic channel.
Old 11-07-2012, 09:02 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Here we don't worry about snow, so this may not work for you.
Meter base centered about eyeball, with a mast up the pole to connect to the poco lines.
A short nipple from the bottom of the meter base to the diso, then out of the disco under ground to the panel.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 08:03 PM
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
Running power to small barn in VA from home service 350' ribertgropius Electrical 9 06-12-2010 02:18 AM
Cost to run electric service to home 500 feet away skinnersone Electrical 2 08-26-2007 04:07 PM
