Mobile Home Service - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 08:56 PM   #16
Electrical Contractor
kbsparky's Avatar
Sounds like a lot of trouble installing a J-box and changing wiring methods to SE-R cable.
We just run the PVC conduit from the stub-down to the slab/ground under the trailer, and then go horizontally on the ground to the outer wall ... then into the ground and back up at the disconnect box.
One run of conduit, and then install (4) type XHHW conductors from the disconnect to the inside panel without splicing.
-KB
Old 03-12-2013, 09:21 PM   #17
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I also would do a run of wire and conduit without splicing splicing is more expensive than just doing a full run of the wire.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-12-2013, 10:15 PM   #18
Rewards Points: 512
Well, the trailer isn't there yet, and the foundation will be poured before it gets there, so matching up the down-stub with one piece of conduit isn't possible. I'll have to run a piece of 40 from the disconnect, under the slab, and back up, and, then, once the trailer gets there, I guess I'll have to crawl under and bring it the rest of the way to the panel. See what I mean?
Old 03-12-2013, 10:41 PM   #19
rrolleston's Avatar
When do a job like this I get a diagram from the company making the home and get the conduit as close as I can to where the diagram. I use flex from where the conduit comes out of the slab to where it goes into the conduit coming down from the home.
The Following 2 Users Say Thank You to rrolleston For This Useful Post:
sirsparksalot (03-19-2013), stickboy1375 (03-19-2013)
Old 03-19-2013, 12:43 AM   #20
Rewards Points: 512
Update.
Rain, rain, go away! The mud out there is a playground.
I'm still in the trenching steps. The foundation guys came and poured concrete footers BEFORE I was able to dig my trench, and get the pipe underground and into the underside of where the trailer is going, so NOW, I get to trench under the footers to get into the trailer undercarriage.
I've no idea how much concrete there is to the footers (10" says one guy, but not sure I should believe it til I see it).
The fella who was going to dig for me - didn't - since the excavating guy told him he's seen lots of pipe laying across the ground. See, they're planning on back-filling to raise the grade abt. 20" between the pedestal and the trailer line, so therefore, the pipe will be at or below 18" after that. BUT, "this is sometime in the future after they place the concrete blocks atop (?) the footers around the foundation". I don't know what the hell they're planning.
I want the pipe buried 18" to the top of the pipe, and I am not wanting to wait for the damn excavating guys to finish. They need to work around me!
Seemed pretty simple to me: dig 48" 6x6x8' post for meter base/disconnect, place them back-back on the post, dig 18" trench from disconnect side of the post about 6', to get the pipe to the underside of where trailer is supposed to sit, cover the pipe with dirt. After trailer arrives, I measure to be damn sure that the inside panel is where it's supposed to be, buy the wire and run it through the pipe, and up to the panel.
Anyhow, going back tomorrow, even though the mud is ankle high, and dig my trench before the trailer arrives Wednesday. I surely don't want to wait until after it arrives, do I?
Lookin' for lessons learned speeches
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
mobile home half electric outlets not working...please baby327nd Electrical 11 02-07-2013 10:51 PM
mobile home renovations dbales General DIY Discussions 3 02-05-2013 06:38 PM
Replacing end walls in mobile home. rrolleston Building & Construction 8 02-02-2013 03:19 PM
