Mobile Home Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 07:26 PM   #1
Question
mobile home light switch
I have a few light switches gone bad in my mobile home. They are not the common light switches. How can I convert them to the common light switches.
handy mama is offline   Reply With Quote
Old 03-12-2009, 07:39 PM   #2
Why convert? Why not buy new replacements!
Old 03-12-2009, 08:07 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Replacements will be hard to come by.
Do you own or rent?
If you rent, call the landlord and have him send someone out.
If you own you can remove the all-in-one device and install a cut-in device box and conventional device.
Old 03-12-2009, 09:48 PM   #4
What is best to do is take out the old box which is usually a fake box, you know the ones with the built in cover-switch with the cover that screws to the wall and there is not a real box behind it...if that is what you have. Replace them with a real plastic pop in box and convert to new switches. Usually the wire is not marked so be careful with the new wiring.
patriot1 is offline   Reply With Quote
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 02:39 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 06:22 PM
Wire hot with light switch turned off dangerouswithtools Electrical 3 06-17-2008 07:56 AM
4-way switch and light fixture rtyui2 Electrical 3 12-23-2007 09:48 PM
Light switch not working! jtbel Electrical 4 12-09-2006 06:34 PM
