Mobile Home Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2012, 05:18 PM   #1
mobile home dimmer switch
I'd like to replace the wall switch with a dimmer switch in my mobile home. The current switch is a self contained switch without a wall box. The switch fastens directly to 14 AWG Romex. Where may I purchase such a switc?
billneill is offline   Reply With Quote
Old 12-03-2012, 05:31 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
You need to Kill the power, cut the wires, install a cut-in switch box, then install a standard dimmer.
Old 12-03-2012, 06:37 PM   #3
Rewards Points: 13,446
It's called an old work box, looks like this.
Make sure the walls are deep enough to install one before buying one.
http://www.bing.com/images/search?q=...09D7A8&first=1
Often time mobile homes have paper thin walls.
Old 12-04-2012, 11:07 AM   #4
depth shouldnt be a problem, we have replaced receptacles in two mobile homes and neither had any problem fitting the old work boxes, even the walls made of 1x3's fit without a problem. Not contradicting you, Joe, just my two cents. good luck bill
Texas Couple is offline   Reply With Quote
Old 12-04-2012, 01:41 PM   #5
Oso954's Avatar
Rewards Points: 986
This one works well for shallow spaces.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=202077341&storeId=10051&l angId=-1&catalogId=10053&ci_sku=202077341&ci_kw={keyword} &kwd={keyword}&cm_mmc=shopping-_-googleads-_-pla-_-202077341&ci_gpa=pla#.UL5Rs4awV7k
Oso954 is offline   Reply With Quote
Replacing a Dimmer switch with a standard switch zenox Electrical 4 07-26-2012 08:58 PM
mobile home self contained light switch bereacj Electrical 8 06-09-2012 01:13 AM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 03:26 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Mobile Home Light Switch Thoward002 Introductions 1 03-26-2009 01:02 PM
