Old 12-13-2012, 12:23 AM   #16
" Euro " electrician
frenchelectrican's Avatar
Mixing of Wires Question
Originally Posted by fa_f3_20 View Post
Did you say it's all in conduit? If so, and the conduit is continuous to all of the boxes, and the boxes themselves are proof against water entry, it should be OK. Cable inside conduit is unorthodox, but I don't know of any rule against it, as long as the conduit isn't over-filled.
As long if this conduit is used outdoor then it have to be UF cable not the NM due the wet location and the condastion will build up inside the conduit that something you will have to think about it.
Merci,
Marc
Old 12-13-2012, 12:33 AM   #17
Yes, it is all in conduit and all the joints have been cemented and also have weatherproof caulk around every joint. THe PVC conduit says 3/4" SCH 40 and so looks as though it has loads of room as only one 14/2 wire in it. Will condensation build up that much inside the conduit to cause a problem? Could I maybe drill a small hole at the lowest points of the conduit so if condensation does form it will be able to seep through small hole?
starrapido is offline   Reply With Quote
Any electricians? Question about a DC switch. Switch is on ground wire(s). Deck Electrical 22 01-14-2012 05:21 PM
Question about connecting wires to the RTH2300 (honeywell) thermostat crap_at_diy HVAC 3 11-26-2011 11:50 PM
running wires / NEC question duhtroll Electrical 6 07-20-2011 04:22 PM
Running wires alongside or through ductwork j_sun Electrical 1 07-13-2011 12:11 PM
Simple (?) line/load question: 3 wires (2 black, 1 white) for 2 spots Local Dimwit Electrical 3 07-13-2011 11:26 AM
